Z1 VRX60B vs?
5thZ
Greenville, SC
It's interesting because you'll see very different graphs from AMS, Sonic (in my humble opinion the leading tuners for the new Z) than Z1.
Here's an example, with E60 and VRX70 turbos. It doesn't look like it lacks much if at all. Courtesy of Instagram about 20 minutes ago
Go2ZZZ
Murdock
EDIT: Saw some of your previous posts. You know what you are talking about, and have a great grip on the "totality of adding other upgrades".
Leaving my post below for posterity.
If you are in to bigger turbos, that means the whole "upgrade suite" is probably either done or in-play.
- Exhaust
- Intake
- UDP
-LDP
- Tune
-Ecutek tune
If I was throwing that much $ at a car, I would want to make damn sure everything was harmonious, and not marketing BS.
Boosted6 knows their stuff. JonnyG has done some pretty cool upgrades. Or, find a dedicated shop. Sorry; I have no experience with any.
Oh you will need much more then that.
stage 2 injectors and stage 3 HPFP and upgraded LPFP.
these turbos excel with Ethanol which means you will also need a flex fuel kit
NocturnalEmber
East coast
24 Z Performance
They don't have a chart for the VRX80B.
It appears the VRX70B crosses over slightly after the 60B, call it 3650.
WHP: VRX70B exceeds stock around 3500 and exceeds the VRX60B around 3550
WTQ: VRX70B exceeds stock around 3700 and exceeds the VRX60B around 3875
BLUE = Stock
ORANGE = VRX60B
GREEN = VRX70B
EDIT: These were manually generated based on actual dyno charts from Z1, so they're not dead-on-balls accurate, but very close.
VR30Z6spd
Sultan
KSA
Z 6spd
while there is a bunch of upgrades to the fuel system that is required to make upgraded turbos shine
comparing a stock tuned FBO Z with just upgraded VRX60s would be clear on Pump Gas
upgrading LPFP and HPFP on and keeping injectors stock
Go2ZZZ
Murdock
highly recommend to upgrade injectors. This info is all over the internet from top tuners
5thZ
Greenville, SC
It seems the VRX60's would be the smoothest driving as both the HP and TQ are smooth linearly across both. No big jumps like on stock or 70s, at least in the powerband that was provided by our good sir @FSUZ33 The graph unfortunately though doesn't show the lower rpms or higher rpms past 4000.
But I also wonder how must of that concern could be tuned out with ethanol by a good tuner like AMS or Sonic?
ZMidlife
ZMidlife
Louisiana
Industrial Gas
Everything i can see the vrx60s would be great for a street car
5thZ
Greenville, SC
Si. Just found out that AMS offers their ALPHA 10 turbo kit for the Z, but I dont see any graphs for it...
VR30Z6spd
Sultan
KSA
Z 6spd
alpha 10 is gonna be 1000HP at least going by what they used to called their GTR kits
5thZ
Greenville, SC
That is what they said on instagram. CZP also says they're going to be pushing over 1000whp with their dual Garret 550 kit. I'm nowhere near ready to get bigger turbos so I hope everything will shake out over the next year and people can start seeing apples to apples against products
Katum68
Mr Laurie
Nashua, NH
Thank you all for this info. I am taking my 2024 Z Performance to Z1 in August for the VRX60s turbos and associated plumbing. Already upgraded to Z1 brake sets and NISMO everything else: intakes cooling, exhaust etc. I'm 80 so I don't need 600+RWHP. My 370 Twin Turbo Z had 512 RWHP (Z1) and I'll settle for that.
This will be a nice build, I am looking to do the same thing, I’m happy at a solid and reliable 500+ hp.
VR30Z6spd
Sultan
KSA
Z 6spd
you can get really close to that power with FBO and lower pressure pump and high pressure pump and E70-80
right at 500 rwhp
