Oil Recommendation
DBZinTN
Tennessee
Technical Sales
Newbie to the forum and certainly not an expert, but being my first Z, I did a bit of research on mods. Also spent time time researching the viscosity thing. There are many "oil expert" videos out there that break it all down, but the short of it is, manufacturers are moving to 0W-20 for compliance more than anything, particularly with models sold in the US.
At 700 miles I changed to Mobil 1 5W-30, installed an aluminum oil pan and undershroud. No track or crazy driving, but I'm in the South and want to take care of my Z. The Z1 oil pan is deeper, 6.5qt capacity now. And the undershroud seems very well designed, with vents and an angle that seems like it will help "pull" air from the lower engine. Think it's the power steering oil cooler right above the vent. I have a '25 Versa I'm also putting 5W-30 in this weekend. Versas were spec'd at 5W-30 previously.
I get sticking with manufacturer recommendation for warranty, but I'd challenge that BS after learning about how much CAFE and EPA regulations impacted the move to thinner oils.
That's the engine oil cooler above the ducting.
Nice choice on the oil pan and under panel!
Your K&N oil filter has the incorrect bypass pressure rating.
DBZinTN
Tennessee
Technical Sales
Oh oil cooler even better. Interesting thanks on the oil filter. Well damn back under while I'm at the Versa then
You will want the OEM Nissan 15208-65F1B or 15208-65F1E.
You may find some old stock B's, but most dealers have made the switch over to the E's. From what I've seen, the A's are what's installed at the factory.
DBZinTN
Tennessee
Technical Sales
Thanks I just grabbed a couple 65F1E. I just did the swap so should be good till they get here.
alutwon
usa
0W20 in a twin turbo car seems crazy to me with how much a turbo shears the oil. I hear 0W20 is very shear resistant but I still change at 3000-4000 to be safe. may make the switch to 5w30 now that my free changes are used up.
I think we have had this conversation, but it makes sense to post it here.
The bypass filter is for a PSI DIFFERENTIAL across the filter elements. In the K&N filter, it has a bypass setting of 15 PSI. That means, if the filter elements get clogged, and they block flow, and pressure across those elements reaches 15.11 PSI, the oil will flow through the bypass.
Car oil pumps are positive displacement. You can't block the flow of oil. It is going to go somewhere. The bypass prevents the filter elements from tearing and blowing out.
I believe Nissan made their filters have such a high bypass PSI so ALL VR30 oil gets forced through the filter elements, preventing debris from bypassing the elements, and clogging the solenoid.
I am currently using a non-Nissan filter and 5w30 with the solenoid disconnected. I change my oil every 4-5k, so I don't think I am clogging up my filter to cause a huge pressure differnetial.
Agree with @Mugzilla 100%
I do NOT want to start a debate, and my personal preference is to stick with a filter with a recommended higher bypass rating. But if you’re using spec oil and changing regularly (5k or less), unless you have something going wrong in your engine that’s contaminating the oil and clogging the filter, a lower bypass filter, say 15 psI for the sake of this situation, will probably not bypass much, or maybe not at all between changes. Especially on a low mileage VR30.
I do also wonder if it has something to do with the variable oil pressure pump/solenoid? GM is also very adamant with their bulletins stating those vehicles required a higher bypass pressure (22psi) vs. the previously used 14-15psi filters.
Or... It's just because of these ridiculously long oil change intervals manufacturers are recommending...
zeroptzero
Joey
Ontario
26 Z
Hello everyone!
What oil brand do you recommend for the Z? Is this a good brand for 5W-40:
https://www.z1motorsports.com/engin...otul-8100-power-engine-oil-liter-p-48710.html
I not sure what is the stock oil for the Z when you take your Z to the dealership. Thanks!
I bring home my 26 sport auto in a couple of days. I have been really happy with Amsoil 5w20 in my Subaru BRZ, I like using the oil over 0w20 as it has a lower Noack volatility number compared to the 0w oils. I only drive my car in summer pleasure use conditions and it is stored in winter. I don't have an issue with 0w20 but I prefer lower oil consumption if possible and lower Noack numbers seem like the way to go for me. Amsoil signature series is my preferred oil brand, but I would be happy with Penzoil Ultra as well , easier to find over the counter.
Sabbi
Nissan Z 2024
Hi Everyone, I just came off the dealership service today, and to my surprise I find the dealer ship has put 5W-30 in this time, that is a change from the last 0W-20 i received. I am happy about this change as I had asked for it last time, but they said they had no such recommendation from Nissan on this.
Looks like something has changed for good. I can now look forward to a tune.
zeroptzero
Joey
Ontario
26 Z
There is a massive shortage of 0w20 synthetic due to Trump's war. There is rationing happening and Nissan has to swap in 5w30. The base synthetic fluid comes from the Middle East and shortages are happening. They have no choice but to use 5w30, it won't be fully synthetic IMO.
Apex_Z
North Orlando
Florida is hot AF and i use the engine aggressively a good bit. I use 5w30 mobil 1 and the oem GT-R filter. I did not arrive at that decision on a whim.
Sabbi
Nissan Z 2024
That would be a problem, but i got the 100k warranty plus a supplemental warranty. Better yet, its the winters now. and my next oil change won't happen until March. Hope this shortage is done by then. However, there are Shell refineries up in Canada making 5W-30 and 5w-40. i think we should be fine and its full synthetic.
Plus the order on the paper work pulls it from the BULK buy option - which would be a Barrel, i doubt anyone has non synthetic on stock at this point.
