Ohlins Coilover Setup
RSS
Scott
Indy
ā€˜24 Z
Hmm shouldn’t be bouncy. How much of a drop and what are your settings for reference?
I had all my parts out ready just to find out mine had to go back.
Me and SPL waiting again.
Suzuyabot
Dante
PNW
2024 Nissan Z Nismo
I wouldn’t say it’s bouncy, but pretty firm. Just wanted to describe the outcome when the suspension get more stiffness. The height is 5 3/4ā€ front and 6 1/4ā€ rear. And only the coilover and Nismo(same as SPL) upper front control arm.
  • Like
Reactions: RSS
RSS
Scott
Indy
ā€˜24 Z
Understood
Imperial
Southern California
Just adjust them to the softest setting and work your way up to the desired firmness. It's the whole point of these coilovers.
Suzuyabot
Dante
PNW
2024 Nissan Z Nismo
Yes I’m still adjusting the firmness to try to find out a good setting for daily and track. The reason I was concerning is that I’m getting some clubk noise on rear struts when going over some bumps or holes on road. So yea gonna need to take some time to find out.
FlagonFly
Memphis, TN
2025 Z Perf 6MT
IT
Been eyeing the Ohlins set at Z1, if I stayed with the Ohlins recs and only drop about an inch would I need to replace any of the other suspension parts, or is that really only needed if dropping lower?
You should always replace the arms because there is no factory adjustment and you want to be able to set your alignment spects
100x more important when you get new wheels
Murix
SF Bay Area
I want to replace the arms even on stock suspension. I am still confused as to why any sports car does not allow range in suspension alignment. I am convinced most of the benefit most people think they are getting from lowering springs is actually just more front end negative camber.
Because Nissan cheaped out
same lack of feature since the Z33, so its been almost 20 years that they failed to account for this
add to that an incredibly conservative alignment and it's no wonder all the Z platforms are understeering pigs out of the factory
I am not a GTR expert but a cursory search indicates Nissan gave it limited camber adjustment in front via eccentric bolts. Like the rear, it's maybe a degree of adjustment, so you need aftermarket arms to do any real changes
Still, better than nothing.
Imperial
Southern California
The increased NVH is very likely just the price you pay for going full coilovers in the rear. The car is designed for a divorced setup which spreads the extreme forces of supporting the car's weight and dampening bumps over different points on the vehicle frame, but you have now concentrated all that stress on a single mounting area. It stands to reason that this is going to cause more flexing and the noise associated with it.
Suzuyabot
Dante
PNW
2024 Nissan Z Nismo
That’s absolutely right, and I was aware of it. So just checked to make sure everything is torqued correctly. Other than that I’m ok with everything.
RSS
Scott
Indy
ā€˜24 Z
Working on the fronts now, one FUCA in place and mounting coilover. I have a msg into SBG but thought I’d ask here. When mounting to strut towers there is a black ring glued to the top side for nuts. Did you remove this or keep in place? My mounting studs are not long enough and wonder if that needs to go or I need to replace.
i ended up replacing stock 25mm with 35mm to get the required length plus some.
On the rear you will need to also get a longer lower mount bolt with nut since the Ohlin is beefier and the stock rear strut has the nut attached.
Almost done, all my SPL parts and coilovers are on, front adjusted down slightly now. I am currently waiting on an answer of required preload from SakeBomb for the rears. Right now the shock is bottomed out in the lower housing and it’s sitting way to high in my opinion for the setting.. Absolutely no information came with the coilovers and with having to source some hardware mid install it’s taking a lot more time then anticipated to this point.
RSS
Scott
Indy
ā€˜24 Z
While I am waiting for a return message from SakeBomb concerning preload adjustment for the rears (see ^ edit) I did some looking at different pictures of FSUZ33’s rears vs mine. Mine are FP Spec Road/track, Not sure how much difference in set up but look at my preload set up out of the box 1st pic vs his 2nd pic. I wonder how far off mine is, I know it was a quick turn around.
