OEM Oil Filter part number?
Has anyone tried the Nismo oil filter? Z1 says it allows better flow. P/N 15208RN011
JonnyG
Jonathan
Nope - Nissan 15208-9E01A Amsoil 0W-40 and disconnect oil solenoid. Did my oil today 9,800 miles 4th change
phil_chronicles
.... disconnect oil solenoid. Did my oil today 9,800 miles 4th change
I plugged my solenoid back in. While i didn't care that the CEL was on, clearing the code also reset emissions stuff to not ready.
Since I plan on doing my recall, I'd rather them not bring it up. Did you know your check engine light is on? We can scan it and charge you $300 to tell you what the issue is ?
JonnyG
Jonathan
The tuner bypasses the CEL
phil_chronicles
I didn't know that, thanks for the heads up. So if the light was on all the time how would you know if you threw a code.
OBD2 reader will let you know what code is coming up. For the oil pressure solenoid, its p06da. It doesnt change anything with it unplugged. My oil pressure stayed the same
speedjuno
Speed
Louisiana
Kubota L3301
None
Just reading this thread.
is there a Recall to address this solenoid problem?
Just ordered the 15208-65F1B (made in Japan) from Melloy Nissan dealership on ebay (full box - 10pcs) for $80 including shipping and tax. I will never buy the mexico oil filters (15208-65FOE or 15208-9E01A).
JonnyG
Jonathan
phil_chronicles
The 9E01 filter or like, is what the tuners recommend - it's "larger" I've used (3) so far. Also, if you choose, disconnecting oil solenoid isn't a bad idea.
https://www.sonictuned.com/post/vr30-engine-failures-without-warning
https://goracebox.com/blogs/guides/infiniti-q50-q60-and-nissan-z-vr30-maintenance-guide
I use the same filter
Just to update, you will get a CEL with disconnecting the solenoid. A tune will turn that off
Pain in the butt to unclip the harness. I used a 90° pick tool to pull down on the clip and long small tip flat head screwdriver to pry it off. I taped it to keep debris out
JonnyG
Jonathan
Getting that connector off does suck - the clip is a pain. You have more OCD than me - I didn't tape :ROFLMAO: :ROFLMAO:
Lisle makes a bunch of these tools for electrical connector removal that work great. What sucks on older cars they get brittle from heat so picks do work better so you don't break
Trying to figure out which filter based on RELIEF VALVE setpoint in the filter:
15208-65F1B (made in Japan by Mahle) : 250 kpa / 36 PSI
15208-65FOE: 98 kpa / 14.2 PSI
15208-9E01A: unknown. My google-fu is weak
Mobil 1 M1-108A: 103 kpa / 15 PSI
Mobil 1 M1-110: 103 kpa / 15 PSI
Per Z1 Motorsports:
*ATTENTION*
If you are using a heavier oil weight than recommended in your FSM, we recommend using the 65F0E filter to allow the heavier oil to flow properly.
