Aero and Top Speed Limits
zeroptzero
Joey
Ontario
26 Z
I'm no fluid dynamics engineer... But, I have a new OEM front chin spoiler in the garage awaiting install, and that thing is so flimsy, it's more likely to fold in half than provide any real aero at 130+ MPH. My guess is the speed limiter difference is a faux-"benefit" they gave the Performance. Zero cost to implement, and a big juicy bulletpoint to add to the Performance spec sheet for the upsell. Someone at Nissan got a major attaboy for thinking that one up.
Yeah exactly, my OEM Nissan front lower lip spoiler is super flimsy, it probably folds over at speed. That's why I am very surprised.
Stefanovich
steve
Australia Victoria
2023 Proto Z M/T
retired mechanic
l wonder if cars in the US have extremely inaccurate speedo readings as we in Australia have. ( l believe it’s a government thing) Mine reads 5-6% high, l use an aftermarket GPS heads up display.
HarryBo
Barry
'24 Z Nismo
Let's not forget undercarriage. Low smooth underbelly is helpful, especially if there are strategic fins directing air flow. I added a Mishimoto front pan to my Nismo, hoping that an added benefit is reduced turbulence and lift.
Brandon, Fl.
That's why I have avoided adding one to my Sport model, I agree with you. I think it looks more like the old 240Z without the spoiler, just my opinion though. I added the front lower lip.
it definitely looks more like the old 240Z without the spoiler. If I had your model, I would only put wider tires.
zeroptzero
Joey
Ontario
26 Z
Thank you, I agree. Yeah wider tires is a good thing with this car for sure. I like the factory 18 inch rims in terms of design and appearance, tires could use more bulk. My model comes with Yokohama Avid tires, maybe not the gripiest of tires
Can't be any worse than the Performance trim Bridgestones. Then again, neither could a used Tiger Paw from a rusty 80's Cutlass... Probably the worst tire I've ever had on a sports car.
Brandon, Fl.
I do love those rims as well. Maybe some spacers would take care of that in order to keep the same rims.
sarge
steve
Western Slope Colorado
2024 Z Sport
Retired Army
I hit 153 in my C5 Vette driving thru Western Montana on I90 in 05. That was as fast as I’ve ever been or probably ever will go again. It was a rush tho.
I believe they're TE37 Ultra Track Edition 2's. Not sure if they're still made/available (they're not on RAYS's VOLK product page. Not a lot of difference from the Saga S-Plus, especially the Black Shadow Ltd version. Main thing at a distance is the machined groove around the lip. Not a huge logo guy, but I like how the Saga S-Plus Black Shadow Limited editions have both the RAYS and VOLK RACING logos machined on the spokes.
A lot of people feel TE37s are basically the definition of cliche at this point, and I can understand why, but I still love them. A Forever Classic imo.
karandras
Gabe
Austin, Texas
2024 Performance MT
Government
I had my stock 2024 Performance up to 145 on a Texas toll road and it felt completely stable and definitely had more to give but my exit was coming up in a mile.
I had my 2002 stock Maxima 6 MT up to 144 on I-75 back in the day and it was pretty much at its limit…. less stable than the Z…. but still impressive for a sedan.
You'd be surprised how much even a tiny spoiler can reduce lift; here is a good video (the channel has other great examples): Do Tiny Rear Spoilers Actually Do Anything
That fingernail height spoiler cut rear lift 25%...
Other famous examples are the Chrysler crossfire and the 911 in the 90's. Both used deployable rear spoilers because the cars shapes created massive lift at speed and could (and in the 911's case DID) cause crashes. The designers though thought the spoilers/whale tail needed looked ugly, so the deployable spoiler was used to keep the looks at low speed and not kill you at high speed.
Also the under chin spoiler IS functional even if it is somewhat flimsy. Stick you hand out the window at 90 miles an hour, the actual amount of force isn't that huge and the spoiler definitely stays intact at high speeds.
I think the disconnect here is that because it cancels hundreds of pounds of lift, it itself has to bear hundreds of pounds of force, which is just not true. The under chin spoiler is there to block airflow under the car causing a low-pressure zone under the car that results in hundreds of pounds of force spread across the entire bottom of the car.
Speedforme has a very minimal spoiler that might still provide stability benefits: Nissan Z RZ34 Rear Wing Type 1 – SpeedFormeUSA
Our car is very sloped in the back similar to the old 911, so it probably produces massive lift at speed with no spoiler...
Someone should make a big knuckle ring shaped like a rear spoiler, dry carbon (obviously), so you can make downforce at will just by sticking your hand out the window.
