Rear end whine on NISMO Z, manual...
zeroptzero
Joey
Ontario
26 Z
If there wasn't a warranty concern I would recommend swapping the fluid to a better quality fluid like Redline or Amsoil . If you are worried about warranty dump the fluid and refill with factory recommended fluid, but I guess the dealer should check it first.
I dumped the factory fluid on my Sport at break-in period, and replaced with Amsoil Severe Gear 75w90, and it is quieter and smoother than ever.
SleepyD7
David
Gainesville Florida
2024 Manual Nissan Z Performance, 2013 Nissan Xterra, 2020 Lexus IS3050
Audio Video Integration Sales
I had a bad ground wire in an after market head unit/audio system that made a turbo/supercharger whine with acceleration only.
Shumax
Curt
Wooster, Ohio
2027 Nissan NISMO Z, manual
Sales
Hmmm, I've kinda heard that whine noise... I thought it was because I did a muffler delete.
Well, the dealership said it's normal and there is nothing wrong. I guess I'll just have to keep an eye on it and see if it gets worse...
With that in mind, you may want to drain & fill the differential to at least get the break-in debris cleaned out. Keep records/receipts of what you used (75W-90 GL5) and when for warranty claim purposes.
zeroptzero
Joey
Ontario
26 Z
That's what I would do, Amsoil or Redline gear oils, I think you will find reduced noise with them compared to stock fluid.
Shumax
Curt
Wooster, Ohio
Sales
The vehicle only has 300 miles on it. Shouldn't I wait a bit longer, or....?
1200 miles is break-in, I find it best to just go ahead and do it all at 1200 miles. Oil, MT fluid, and differential fluid.
Yes, agreed! 1,000 or 1,200 either way regarding changing all fluids.
  • Redline MT-85 for the manual transmission fluid
  • Redline or Amsoil 75W-90 GL-5 for the rear differential
Shumax
Curt
Wooster, Ohio
Sales
Is the dealer going to use those fluids if I ask? I don't mind paying for it; but wonder if they'll give me a hassle given it's still under warranty....?
Likely not; they'll want to use the Nissan OEM fluids. These are very simple DIY jobs if you don't mind getting under the car and spinning a wrench, otherwise any independent or performance shop could easily tackle it with your requested and/or supplied fluids.
Osage
Wade
Austin
2027 Z Nismo MT, 2026 Pathfinder Rock Creek
@KrackaC8 you are the best. Can you give us a list of all recommended fluids? Already going to put the Water Wetter and distilled water in the new Heat Exchanger.
I did the engine one at 1100 and then the rear one at about 2020 since I drove it from Phoenix to Tampa, Fl.
KyleWI
Kyle
Wisconsin
27 Z NISMO
*Redline MT-85 - Manual Transmission
*Redline 75W90 Hypoid - Diff
*Oil - We should argue over this.
*Coolant - Use OEM Nissan blue and add WaterWetter
*Brake Fluid - DOT4, street or Castrol SRF, track
*Clutch Fluid - Motul RBF 600, also an option for the brake fluid for track. I strongly suggest people change this too.
My list is very similar to @KyleWI with just a few variations. Here's my preferred list and what's in my personal car:
  • Manual transmission: Redline MT-85 GL-4
  • Differential (LSD): Redline 75W-90 GL-5
  • Engine oil - Pennzoil Ultra Platinum 0W-20
  • Engine oil filter: OEM Nissan 65F1B/E
  • Coolant additive: Redline WaterWetter
  • Brake fluid: ATE TYP 200
  • Clutch fluid: ATE TYP 200
