Downpipes & Best Practices
Hernandooo
Hernan
Straya
2024 Nissan Z, Trek Bicycle
Aaaaa I went Catless LDP too. Only reason to up grade to FDP is if you are upgrading turbos and going for big big power. Other than that LDP upgrade is adequate with oem turbos up to 480HP to wheels.
Maybe 480hp at the crank, not the wheels. With the same setup as the AMS alpha package, I can see that happening
ā€˜25 PRFM M/T
5" diameter? That's a bit overkill for fdp
I would just match it all the way through?
I agree - but not seeing an exhaust that is straight thru. They all have x / h pipe section that is less than straight thru. I’m looking at installing 3ā€ lowers merging into what size x / h pipe? 4 or 5ā€?
So far it looks like the AWE is the best option. Their X/H pipe looks like a slight bottleneck. But since it’s 3ā€ pipe, i’m guessing a little neck-down in that area is not going to hurt. Should still be ~5.5ā€dia.
i like remarkā€˜s clean lines but wish they made a 3ā€œ version. not sure about 2.5ā€ inlets merged into a 3ā€ single then split back into 2.5ā€ pipes?
invidia’s x pipe looks good. I guessing it will flow like a ~5ā€ pipe…
https://invidia-usa.com/products/invidia-22-up-nissan-new-z-dual-n1-s-s-tip-cat-back-exhaust
Hernandooo
Hernan
Straya
ā€˜25 PRFM M/T
Boost logic look bad to the bone and their x pipe merge looks like it keeps a full 6ā€ cross section area - like a true dual. my goal is the keep the catback cost to <2K.
With that said I’m not looking for 4ā€ pipe. i think 2.5-3ā€ pipe dia. is good to go.
my concern is the merge collector on some of the these exhuast designs.
Looking at the remark setup, two 2.5ā€œ pipes (5ā€ total) necked down into a single 3ā€ merge collector. what is the 3ā€ merge collector hp limit @ 17+ psi boost? The only reason I’m looking at the remark setup - i love how smooth / straight their lines are - the fewest bends of the bunch. but I’m not sure what hp the 3ā€ collector is good for.
Stillen list their X pipe’s cross sectional area (4ā€). So that 5ā€ feeding into 4ā€ - better than 3ā€. AWE is feeding 6ā€ into what looks like 5.5ā€+
The AWE touring flows more then you will ever need, the piping is pretty straight, and the collector is large enough diameter to meet any HP number you could dream of.
ā€˜25 PRFM M/T
no concerns with the AWE. My concern is wih the remark 2.5 piping into a 3ā€ collector. any idea what the HP limit for a single 3ā€ merge collector?
You won’t make enough power with this platform to worry about that. Unless you are building the motor and going big turbo, you won’t have any issues. My GT500 was stock 2.5 exhaust and cats, I was making 700hp to the wheels and had no issues.
ā€˜25 PRFM M/T
AI to the rescue. Looks a 2-1 (2.5ā€-3ā€) merge collector is good for ~500-600hp. Iā€˜m sticking with 93 pump & stock fuel system, so remark should be good to go…
ā€˜25 PRFM M/T
Thanks for the intel. I’m only doing intake, lowers & catback w/ ecutek. I was looking at going with a remark catback exhaust and was concerned with having a 3ā€ merge collector as the bottle neck. But looks like that will not be an issue.
A single 3" will be just fine for ~500whp. A single 4.0" will outflow dual-2.5", for example.
On previous builds, I found single 3.0" into dual-2.25" worked out really well and made great power. Going into dual-2.5" just made more noise/drone for zero gains.
It's not about the diameter, but the total area and surface tension.
el mƔgico
I've got the Boost Logic '3. I am pairing it with the '3 Spool Performance full resonated dp. I'll post a clip WHEN the install is complete (for those interested).
Without the dps now I still get a bit of turbo spool with the Boost logic. Let's see how it changes...
Bumflik
Issac
illadel
Bus Operator
Yesssss!!!!!
ā€˜25 PRFM M/T
thanks for the info
ā€˜25 PRFM M/T
Looking at lowers - I see AMS is using studs like oem for installation. Also AMS does not have a logo plate tack welded to the pipe - a plus for coating.
for the brands using standard bolts for installation, would you install all the nuts on the bottom side or keep same direction as stock?
for the logo plates, do you remove or just coat over them?
