Clutch life expectations
TwinZurbo
North Carolina
I'm considering the Nismo twin disc clutch but I'm curious if I'm just being upsold.
I'm tuned to run 18psi with a lower DP, intakes, exhaust. The sale pitch was that I was going to wear it out from how fast the power comes on, not just how much power is being delivered.
I'm only at around 450 ftlbs of torque.
Anyone else see the need to replace or had a clutch start wearing out fast?
I couldn't find many specs on the OEM Exedy clutch regarding torque ratings.
Anyone running the twin disc clutch?
TheRoyalStig
Nj
Yea I would wait until it actually starts failing to do anything there.
If it starts slipping you should have plenty of time to just baby it until you can get it replaced.
PriZ
Seattle, WA
I went for the Nismo clutch right away. This car has a lot of rev hang due to the incredibly heavy clutch/flywheel assembly it comes with. It's a performance modification all on its own. I documented this more here: https://www.nissanzclub.com/forum/threads/nismo-flywheel-weight.1739/.
Long-story short, I would HIGHLY recommend. Significantly improves the drivability, especially as you're turning up the power.
TwinZurbo
TwinZurbo
North Carolina
Great read, really appreciate it. I'm going to ask about tuning out the rev hang.
I found Uniclutch. They have an anti-chatter claim I'll be looking into someday!
Ali023
Ali
Ny
2023 Nissan z performance 6MT
What is your idle at with the Nismo street clutch and flywheel ?
I have upgraded z1 bb turbos with z1 turbosmart BOV kit
Parked in neutral I rev it and rpm’s drop and car stalls ?
my idle is below 1000 rpm like 600 I believe
My friend said to bump the idle up to 1000 because of the lighter flywheel ?
PriZ
Seattle, WA
My idle is around 600-800 as well. Never ever had it stall though. I’d bump it up a bit like your friend said. Maybe try 800 and then 1000 if that still doesn’t work? If I recall you’re also running flex fuel as well so that may be related. Ethanol is less dense energy-wise so the low flow rate at idle might not be enough to sustain 600 rpm with your build.
Ali023
Ali
Ny
Yeah that’s what I’m thinking bumping up the idle
Fbo e85 big turbos injectors etc ..
My tuner gonna bump it up to 1000
RedWinterZ
Ohio
Same FBO set up here as yours. Been looking at the aftermarket clutches but am fine waiting (years) for it to give me a hint.
So, the Exedy is the weak link on the manual?
" The problem for me lies with the Exedy clutch, which is supposedly designed for high performance. The clutch pedal itself feels too light, the travel is too long, and it's hard to feel where the bite point is. As a result, shifting smoothly is nearly impossible "
Driven: 2024 Nissan Z Is A Misunderstood Beast | CarBuzz
Jah_Happy
"Shifting smoothly is nearly impossible" lol thats bullshit. Its also not hard to find the bite point. I wonder about some of these articles.
JonnyG
Jonathan
I'm just excited to see that the clutch and flywheel kits are so affordable for these cars. OEM for my Hellcat is over $4k - just ordered my third (have 190k miles) - triple disc from Bad Boyzz over $4k with HRB. Thank god I do them myself. I asked this on another thread and no one answered - Am I correct in believing that there is not a hydraulic realse bearing on these cars - its a fork, if so I find that a little antiquatied.
Katum68
Mr Laurie
Nashua, NH
If the transmission does not slide Ito gear easily with the NISMO clutch, it may be due to the transmission not being marked correctly for install. I was having a really hard time with the transmission and would have to try 3 or 4 times to get the car into reverse. Took it back to dealer., They got a new clutch, which had the correct markings for alignment, and installed it.. Car now shifts like it is supposed to. Excellent.,
Haha I've had no issues shifting mine smoothly
Yep, now owning one, shifting and clutch take up is easy and smooth after short time adapting. I only wish the take-up is lower so ankle doesn't have to rotate so much up and down. On my G35 I can adjust the throw behind the pedal, not sure yet if this is possible now.
