sdktheway
Scott
Western NC
Nissan Z Nismo, Subaru Ascent
I just changed my diff and transmission fluid and plan to send both off for analysis after doing my oil ~10k miles ago. Very interested to see what they say about the diff fluid seeing as it's gone over 300F on multiple track days since it was last changed
Why the 5-30?
Couple reasons.
Same video. 2 diff links.
Also, check pg 2 of this thread:
https://www.nissanzclub.com/forum/threads/engine-oil-best-viscosity.2606/page-2
@Loco38SUP 's chart, and @Racebox 's posts are great.
0w20 is for fuel efficiency. Someone living in a furnace should go a bit thicker.
NOW, I might as well head this off before you ask:
"WHAT OIL FILTER DO I NEED FOR THIS HEAVIER OIL?"
Big can of worms here, with passion on all sides. (Less arguments will occur if I post if an airplane will take off if it is on a treadmill.)
You should select an oil filter with the correct relief valve setting. Since 5w30 it is a THICKER oil, you will get a higher pressure buildup in the filter. Higher pressure with a low relief valve setting, will cause the relief valve to lift, and oil BYPASSES the filter elements. Higher relief valve setting means oil is FORCED THROUGH the filter with a higher differential pressure across the filter elements.
@JonnyG on pg 4 posted a great Racebox document:
https://www.nissanzclub.com/forum/threads/oem-oil-filter-part-number.2787/page-4
On pg 5 of the above thread, I tried to make an all-encompassing chart of oil filter vs their relief valve setting.
Koryak
John
Colorado
retired telecom instructor
Lake Speed Jr. recently showed some data on YouTube that indicated even modern engines are still breaking in at 10k miles. Matt's 2nd report is what I'll use for comparison to my Z after similar mileage.
Racebox
Diamond Sponsor
Racebox
goracebox.com
2023 Nissan Z
Tuning/ parts installation
Couple reasons.
Hello,
We use the Bosch GTR Filter for all VR30 oil changes at the shop.
This simply provides extra capacity and filtration.
Part number:
72226WS
-Ana
But hey who cares about the differential across the filter.
hard pass on the made in mexico filters.
for oil - i’m switching to 10-30 after break-in. 5 wt. oil is considered sewing machine oil in my neck of the woods.
Found this on FB. Yeah, it's FB, and it is an AI-gathered response.
TL; DR: I'll stick with my 5w-30, and a quality filter with a higher relief valve setting (To force more oil through the filter.)
Hello,
Part number:
72226WS
-Ana
But the relief valve pressure for that filter is 14-18 PSI. If oil pressure in to the filter is >18 PSI, it bypasses the filter element. Now, you also don't want a relief setting of 100PSI, as it will blow out your filter element.
The question is: Is a 15PSIG relief vale, that's good for 0w-20, good for thicker oil?
Not besmirching you, Racebox. You guys know your stuff. Every drop of oil does not need to go through the filter EVERY TIME.
Maybe I'm getting too anal retentive. Bottom line: I'm happy with my Blackstone numbers, will keep doing it, and getting a baseline.
Hope to see other's results here too.
Dealer performed my first oil change with 5W30 M1 and no mention of any filter relief valve changes, just factory filter. This is warmer CA climes. Since documented, I'll stick by this and maybe do the Blackstone on later changes.
