isn't 1.8 degree camber roughly what is stock
On top of the quality of the SPL arms, what some don't realize is that camber adjustability is easily done WITHOUT removing the control arm bolts, as most others do including some Nismo branded. For those that set-it-and-forget-it it's fine but if need to adjust often then SPL's design is awesome, my next bucket list buy.Sorry this happened to you
but people ask me why i only recommend SPL arms and a lockout kit
this is why
Yes. The latest Z1 design, Voodoo13, and GKtech i believe all technically allow adjustment on car, but they all use a generic jam nut design.On top of the quality of the SPL arms, what some don't realize is that camber adjustability is easily done WITHOUT removing the control arm bolts, as most others do including the Nismo branded. For those that set-it-and-forget-it it's fine but if need to adjust often then SPL's design is awesome, my next bucket list buy.
I have their catch can and undershroud, those seem to be good. I also picked up the aluminum oil pan which I haven't installed yet.Man, I feel like Z1 is on blast lately but for perfectly valid reasons. I might order products from them but I will never buy anything that's one of their Z1 branded products again. 4 out of 4 products I've got from them have all had issues.
It’s tough because I want to like their stuff but my experience so far has been all over the place. I will say that their support has always been great though.I have their catch can and undershroud, those seem to be good. I also picked up the aluminum oil pan which I haven't installed yet.
Going to be a little more cautious after reading all this.
Haha, I forgot I also have the z1 spacers, those are good. Hard to mess up spacers I guess.It’s tough because I want to like their stuff but my experience so far has been all over the place. I will say that their support has always been great though.
Here’s the rundown:
Z1 Carbon Fiber Engine Cover - the top half of the cover had a hole that was nowhere close to lining up. Ended up doing a return to replace the entire cover (button included). Top now fits but the bottom fitment isn’t great either now. I have to bend it slightly to line up.
Z1 Duckbill Spoiler - installed professionally 3 months ago and now the passenger corner has already separated from the 3M tape it attaches with. Also creaks like crazy.
Z1 3-point Aluminum Brace - what a nightmare this was. Installed just to have it knock around in the engine bay every time we took the car out. Finally got fed up and took it off to find out that the engine was making contact with the brace in 2 different places.
Z1 Oil Catch Can - the hose clamps they include with this kit are a joke. Had to buy new clamps instead. Additionally, all 3 of the Allen head screws to attach it to the bracket all had 3 different sized heads so I needed 3 separate Allen keys to attach it.
What’s disappointing is that since having all of these parts, I have found threads, reviews, etc. of literally all of these issues so if the feedback is making it back to Z1, they’re certainly not doing a ton to address them.
I literally started looking at new wheel spacers last night since I’ve got the Z1 spacers. Out of all the Z1 parts I’ve owned, I’d certainly like those not to break too. 🫠
No vibration here, not up to 135ish at leastNot saying they're defective...I assume they're not...but I did their 5mm spacers, had a pretty good vibration and pulled them. Although it's supposed to, I assumed the hub center didn't have enough protrusion to perfectly center one or more of the wheels. With all of this quality stuff boiling up I may mic them to see if one or more may have uneven thickness.
I assume they're fine. Not sure what it was though as everything appeared to be seated properly. Started around 15-20, then it would taper off and start back around 30-35. It felt like only one front wheel, but didn't verify/test anything. Just pulled them and moved on.No vibration here, not up to 135ish at least![]()
they will blame you for this bc they will claim they cannot test every exhaustAdd the diff brace to the list. I bought their diff brace a few weeks back and it did not clear my exhaust.
Before they tried this, I mentioned that nowhere on their product listing did it say it will or won't clear '3 exhausts.they will blame you for this bc they will claim they cannot test every exhaust
