Katum68
Mr Laurie
Nashua, NH
They will make a noticeable difference vs stock when set to firmest front. I started with the middle setting but not that much of a difference. Rear is still on soft setting. Flat cornering and well controlled, still on stock springs and shocks.
still on stock springs and shocks. also. I like it. the auto rides flat.
ā€˜25 PRFM M/T Gun Metallic
All stock: When corning - I’m getting bounce (like a riced out civic w/ lowering springs - well maybe not that bad). Will tires & sway bars fix/help this?
the bounce happens with moderate corning - not even close to being aggressive.
Bumflik
Issac
illadel
Bus Operator
Yup!
replace front only or both? Just looking to fix the bouncy house…
Bumflik
Issac
illadel
Bus Operator
Yep do the front and rear and get Swift spec R lowering springs or coilovers.
Replace both, it’s a balanced setup. Cry once buy twice ;)
Fulshear, TX
VP
Stillen rear swaybar installed today to match the front I installed a few weeks ago.
The rear bar made a more noticeable difference than the front did; feels amazing and much more nimble. I have both front & rear on the softest settings. I'll be leaving the rear there, but going to bump the front up to the middle setting.
Katum68
Mr Laurie
Nashua, NH
I am 80. I have the Stillen Sway Bars front and rear. On 3. They are fine. Car is flat in turns. I don't know about the track but for all legal driving (said for legal protection) they are excellent.
Fulshear, TX
VP
You have both bars at their stiffest settings?
Fulshear, TX
VP
tractng
Los Angeles
2022 Miata, 2009 BMW X5
Infrastructure Manager
On the Stillen sway bars, do you need anything (endlinks, etc) else if the car is a little lowered on RS-R springs?
Fulshear, TX
VP
No, designed to retain the factory mounts, bushings, and links.
Fulshear, TX
VP
Just to keep record, I now have the front bar at the middle stiffness setting and the rear bar at the softest, which is what Stillen suggests as a starting point for stock tires/suspension.
