- Joined
- Apr 13, 2024
- Threads
- 42
- Messages
- 685
- Reaction score
- 488
- Location
- Long Island
- Car(s)
- 2024 Nissan Z Performance, 2018 Nissan Murano SV
I've seen varying WHP readings for the stock Z. I've seen 325whp to 370whp.
A lot of variables with dynos. Hub dynos like Dynapack will be real close to flywheel hp. A hydraulic drum dyno like dynojet and mustang will read much lower than a hub dyno. A mustang will typically read lower than a dynojet. boosted engines can vary more than n/a due to heat soak and variation in the boost control. Auto’s read lower than m/t. Like zmidlife said, the dyno software has different options to compensate for test conditions like temp, altitude, humidity, etc. so only real answer is calculating gains / losses with same dyno and conditions.I've seen varying WHP readings for the stock Z. I've seen 325whp to 370whp.
Dynos can vary a lot. I have seen as much as 20% difference. That said, if you take the published HP number from the factory and multiply it by 0.87 you will be damn close to the real wheel HP number. That is 348 for our cars. I would be surprised if one bone stock car to the next (of the same trim/year/etc..) varied more than 5hp from each other in the same conditions. Tolerances and QC are pretty tight these days.I've seen varying WHP readings for the stock Z. I've seen 325whp to 370whp.
Where does the .87 factor come from?Dynos can vary a lot. I have seen as much as 20% difference. That said, if you take the published HP number from the factory and multiply it by 0.87 you will be damn close to the real wheel HP number. That is 348 for our cars. I would be surprised if one bone stock car to the next (of the same trim/year/etc..) varied more than 5hp from each other in the same conditions. Tolerances and QC are pretty tight these days.
Average drivetrain loss is 13% or so typically. Multiplying fwhp by 0.87 gives a pretty good wheel estimate.Where does the .87 factor come from?
Drive it like you stole it ... love this car.What a lot of youtubers skimp on or miss entirely is what attracted me to the Z to begin with. If you look at this car as a canvas ready for personalization, you've just unlocked half the fun and performance of it.
Nissan (maybe to a fault) I believe left the car with a lot on the table. Suspension, exhaust sizing, tires, etc are all on the more relaxed side rather than outright aggressive, but in my head canon, throwing on some PS4S or Sport Cup 2's and other minor additions will give a great OEM+ feel to it. I didn't just buy the car, I bought the experience of owning it.
I know this is a little late, but I'm a new member here. I'm in process of building a 2024 Nismo Z (brand spankin' new). Two questions. One, does this item work with the Nismo Z's configuration? And two, I'm leaning more towards a high end build (goal is 600-700whp). If you have any recommendations, I'm all ears. I have extensive experience in building blown/boosted V8 engines, but this is my first foray into Japanese style V6s, so I'm taking some time to learn the platform before I commit to a full send type build.
You'll need aftermarket turbos to hit these #s.I know this is a little late, but I'm a new member here. I'm in process of building a 2024 Nismo Z (brand spankin' new). Two questions. One, does this item work with the Nismo Z's configuration? And two, I'm leaning more towards a high end build (goal is 600-700whp). If you have any recommendations, I'm all ears. I have extensive experience in building blown/boosted V8 engines, but this is my first foray into Japanese style V6s, so I'm taking some time to learn the platform before I commit to a full send type build.
I agree. I've already looked into a pair of Garretts for the build. As I've been doing research, the more I settle on, the more I realize that Z1's build is fairly similar. My main hangup right now is on the trans/driveshaft/axle half shafts. I'm pretty confident I can work with a shop to square away the power, but as a car, this thing will also be a daily. So, I'm going to build this thing out to be overbuilt and bulletproof. The DS might be OK with this build, but I think I'm going to end up overspeccing the half shafts and the trans past their torque limits.You'll need aftermarket turbos to hit these #s.
The stock turbos are damn near in the center island of the compressor map.
Better intakes, turbos, fuel, exhaust and cooling.
