Break-in period
it just means vary RPMS . just talking about if you are on the interstate for hours and your Z is just sitting at the same RPM for a long time thats all
Brock
Brock
Oklahoma
Nissan 370z
Here's the part of the break-in procedure that I hate.
What the hell does that mean? Is "constant" +/- 0 mph, +/- 5mph, 20, 50, 100? What's a "long period"? A minute, 10 minutes, an hour, a day? Don't even touch the cruise control!
I drove 350 miles today. Have to use Cruise control as there are a number of tailgaters, and sneaky highway patrol along the way. But I try to raise, and lower the speed by 10 mph. We do what we can, and hope that the breaki-in goes well! Although I do do a bit of country driving that changes speed a lot. Can’t beat ourselves up over it! I say! ?
Brock
Brock
Oklahoma
Nissan 370z
Now have 900 miles on it so far. Will drive more tomorrow.
Spartan
Dubai
2026 Toyota Corolla GLI 1.6L
Sales Executive
Also replaced the cabin lights with LED’s from Panda Motorworks. Less than $20.00 makes a big difference!
link please
Break-in run, varying speeds and gears, now appx at 350 mi.
Nurburg_beast
Oregon
2024 Z Performance 9AT Ikazuchi Yellow, 2014 Accord EX-L V6
Just put down the deposit for a Z Performance today and already got nervous lol. I know it is best not to do short trips during break-in periods. But my drive to work is very short (5mins-ish). I do go on 1hr+ drive on the mountain roads near my place every week, and I will definitely continue to do that once I get the car to work the engine through varying loads (while keeping the rpm below 4k). Aside from that, is there any other suggestion to properly break-in the car?
Once you get the car, you'll be looking for any excuse to drive it. That's what happened to me. I'm sure you can find a route that will become the "long way" to work.
You can find the manual online, and it has a section on break in. Just follow what you find there. I think I read the entire manual before I had the car.
@Nurburg_beast It's a quite normal break-in period for these engines, just go thru the gears and varying speeds under 4K. I even nudge slightly over, 4.5K on short bursts, want it to be flexible across the range sooner. At 360 miles now. No heavy launches of course, but I disabled auto rev-match to blip the throttle as normally used to, should be fine to let the engine rev under foot/heel. Bottom line is drive it as how you would normally when under 4K. Plus I don't let the engine idle for long periods, drive it with light foot until it warms up, a few blocks. Enjoy your ride!
Bumflik
Issac
illadel
Bus Operator
Short drives in the winter isn't healthy for DI engines. Gotta allow the engine to warm up to at least 180° Fahrenheit. Also, the fuel mixture in the engine oil increases during colder months due to ecu instructing for spraying more gas at ignition for starting the motor.
5 min drives are torture on any engine.
You can get sludge when normal moisture isn't heated out of the engine oil, engines run a bit rich cold, small amounts of fuel buildup in the oil, and don't get a chance to be heated out of the oil, like water.
A bit worse for DI engines.
Additionally, large amounts of condensation collects in the exhaust, which causes rusting from the inside.
I suggest you lengthen those trips out. I'd be shooting for a minimum 15 minute drive.
Bumflik
Issac
illadel
Bus Operator
Yea enjoy the scenic route and embrace the drive. Leave home early. I did it when for a short period when i used to daily my Z. Always drove for at least 35 min. And I'd hop on expressway for a good acceleration . Go the long way to work haha.
