9AT Transmission fluid flush service
Was wondering if anyone has done this service yet and the average cost for the service (if you didn't do the job yourself). I'm still running the factory fluid and seeing how disgusting the factory LSD fluid was after changing it I'm looking at the trans fluid next, especially since I occasionally track the car.
Don't know intervals on this one, but...
DIY AT service, technically a "drain and fill" doesn't drain all the fluid. I think about half. Still good to do, but shouldn't be substituted for full flush based on factory intervals. With the full flush they hook the car (running) up to something that pressurizes the system and possibly 'actuates stuff' to make sure all the fluid is pushed out. This is another one where a shifty shop can jack you, as they'll do a drain and fill and charge for a full flush. Local Nissan dealership's website shows "Call us" by the price. Guessing it's at least a few hundred bucks.
I got a quote from a local trusted performance shop, and I believe they're also a Nissan certified shop. The labor is $700 which also includes replacing the pan and filter. This shop is a little pricey but they don't mess around. The owner is anal about the work and he doesn't hire bozos. I was just curious about other experiences. To me the transmission is quite important so the price tag seems reasonable.
With what little I know, $700 seems fair.
Speaking with a guy here that was a service manager at a GM dealership, a full AT flush is pretty involved, and was $500 to $1,400 a couple of years ago depending on the transmission (some needed pretty expensive fluid).
~10 quarts of fluid, pan and maybe other parts depending on make/model. And the kicker (right or wrong), that dealerships have gone nuts with labor rates, which has trickled down to independent shops a bit.
Based on my owner's manual (2024) for Standard Maintenance (not "Severe") AT fluid change is not specified throughout the maintenance schedule. However "Inspection" of "Automatic transmission fluid" is spec'd at all 10K/Yearly intervals. Every 10K/Yearly interval it states: "Request the dealer to inspect the fluid deterioration data using a CONSULT. If the deterioration data is more than 77000, replace the AT fluid."
chadgigachad
I think my fluid change was about $300, half of that being fluid. I wish I had a pump so I could do it myself.
mikecarpage
Bay Area, CA
Sales
the local dealership quoted me $420.95 for a Manual Transmission Fluid Service. I haven't done that yet and currently at 5,267 miles.
I have the Z1 tool and fluid. I just don't have the correct fluid pump to pump the A/T fluid into the transmission.
Harbor Freight should be able to get you setup I'd think.
VtVince
Vince
Vermont
'24 Nissan Z Performance, '23 Honda Ridgeline, '24 Mini Countryman S All4
Alex at Racebox changing fluids on a 23 Z AT. This might already be up here somewhere;
Transmission fluid change starts at 10:40
Nice having a lift. I don't have a lift. I have an old broken uneven asphalt driveway.
ShearMe
DFW
2024 Sport AT
Audio Visual Integration
Did mine at a dealership at 20k and could feel the difference. $300 sounds about right off the top of my head
Do you still have the invoice? I'm curious to see the details of the work described.
I've looked into this a little more, and could have asked the dealership Friday, but didn't think about it.
$300 is a good deal if this was a flush/replacement, but was probably a drain and fill...although there's nothing wrong with that.
Total capacity is 10-11 quarts and drain and fill is 5-6.
Nissan's Matic P ATF is $30 per quart ($150-$180), and typically a drain and fill comes with a new pan (~$125 for pan and gaskets).
