Wheel spacers
frankydoodle666
sam
Vancouver, Canada
2027 Nissan Z performance
Hello guys, does anyone know if I can run 25mm wheel spacers on my Z with stock rife height? I like the look of the wheels poking out slightly. Just wondering if there will be rubbing issues. From what I’ve read most people run the 20mm with stock ride height. I might lower the car later and would like to have the 25mm on just incase I do. However if I don’t lower it I would leave the 25mm on there just for a wider stance. Thanks
Bluenoser
Justin
Nova Scotia
Lawyer & Fisherman
I have 25mm front and back. They are branded Akata. Tires do poke out a bit. I bought the front and rear splash guards to try to compensate a bit. The body line around the front tires is such that I think you see a bit too much tire. All personal preference of course but if I were ordering again I would keep the rear 25 mm spacers but go with 20 mm for the front.
sarge
steve
Western Slope Colorado
2024 Z Sport
Retired Army
I have had 25 mm rear and 20 mm front on my 24 Sport Z for 11 months with stock ride height and there have been no rubbing issues whatsoever. I like running thru the canyons "spiritedly" and have not had any issues, I check Torque on the spacers every 6 months and haven't had trouble with loosening.
Get good Hub centric spacers, I went with Mishimoto. You don't need to pay $500 for the Borla spacers but I wouldn't go with the $65 Ebay specials either.
frankydoodle666
sam
Vancouver, Canada
I have 25mm front at back. They are branded Akata. Tires do poke out a bit. I bought the front and rear splash guards to try to compensate a bit. The body line around the front tires is such that I think you see a bit too much tire. All personal preference of course but if I were ordering again I would keep the rear 25 mm spacers but go with 20 mm for the front.
Awesome! Thanks for your recommendation. I think that would look good with the back poking out a little more than the front .
Thank you for the help sir
KnightRiderz
Adam
Maryland
Military
So first mod i did was lowering springs and spacers. I ran 20mm front and 25mm rear. No issues what so ever and it looked amazing. Now I run 20mm on the rear with my new setup. I went with Garage Line.
speedjuno
Speed
Louisiana
Kubota L3301
None
Please forgive my ignorance. But.
Do these 20 & 25 mm spacers require replacing the existing studs?
I went with 15mm front and 20mm rear and it’s perfect. I don’t want any poke just a bit more flush, with RSR springs. Car looks perfect. I did the studs and slip ons, which I prefer over the bolt ons.
frankydoodle666
sam
Vancouver, Canada
Thanks for all the help! I’m new to this and may have more questions. I appreciate the great info!
Awesome! Thank you!
Thank yo
How was your car after lowering springs? Is there a lot of scraping speed bumps and driveways? I’m considering getting swift springs which lower the car about 1 inch. Just hesitant because the Z is already pretty low. However it would make the car look so much better.
How is your car after lowering springs? Does it scrape speed bumps and driveways a lot? Considering lowering but hesitant. Thanks
KnightRiderz
Adam
Maryland
Military
Awesome! Thank you!
Thank yo
No scrapping. I have the swift springs.
sarge
steve
2024 Z Sport
Retired Army
There’s an issue with 15mm spacers not allowing the rim to sit flush on the spacer. Search “15mm spacer issues” and you’ll be able to get the info you need
