Wheel spacers
frankydoodle666
sam
Vancouver, Canada
2027 Nissan Z performance
Hello guys, does anyone know if I can run 25mm wheel spacers on my Z with stock rife height? I like the look of the wheels poking out slightly. Just wondering if there will be rubbing issues. From what I’ve read most people run the 20mm with stock ride height. I might lower the car later and would like to have the 25mm on just incase I do. However if I don’t lower it I would leave the 25mm on there just for a wider stance. Thanks
Bluenoser
Justin
Nova Scotia
Lawyer & Fisherman
I have 25mm front and back. They are branded Akata. Tires do poke out a bit. I bought the front and rear splash guards to try to compensate a bit. The body line around the front tires is such that I think you see a bit too much tire. All personal preference of course but if I were ordering again I would keep the rear 25 mm spacers but go with 20 mm for the front.
sarge
steve
Western Slope Colorado
2024 Z Sport
Retired Army
I have had 25 mm rear and 20 mm front on my 24 Sport Z for 11 months with stock ride height and there have been no rubbing issues whatsoever. I like running thru the canyons "spiritedly" and have not had any issues, I check Torque on the spacers every 6 months and haven't had trouble with loosening.
Get good Hub centric spacers, I went with Mishimoto. You don't need to pay $500 for the Borla spacers but I wouldn't go with the $65 Ebay specials either.
frankydoodle666
sam
Vancouver, Canada
I have 25mm front at back. They are branded Akata. Tires do poke out a bit. I bought the front and rear splash guards to try to compensate a bit. The body line around the front tires is such that I think you see a bit too much tire. All personal preference of course but if I were ordering again I would keep the rear 25 mm spacers but go with 20 mm for the front.
Awesome! Thanks for your recommendation. I think that would look good with the back poking out a little more than the front .
Thank you for the help sir
KnightRiderz
Adam
Maryland
Military
So first mod i did was lowering springs and spacers. I ran 20mm front and 25mm rear. No issues what so ever and it looked amazing. Now I run 20mm on the rear with my new setup. I went with Garage Line.
speedjuno
Speed
Louisiana
Kubota L3301
None
Please forgive my ignorance. But.
Do these 20 & 25 mm spacers require replacing the existing studs?
