- First Name
- Chad
- Joined
- Feb 23, 2025
- Threads
- 43
- Messages
- 1,476
- Reaction score
- 1,771
- Location
- Tallahassee, FL
- Car(s)
- ‘24 Z NISMO
Posted yesterday (above, and on a spacer thread) that I have a vibration, and I'm 99% certain it's coming from the spacers. Plan to mic the spacers for thickness/coplanarity, but I assume they're fine, and the issue is one or more wheels aren't properly centered.I also have the z1 5mm spacers. They said if I could get 6 or 7 full rotations on lugs it'd be fine, how many did you get? I haven't had the opportunity to swap yet as my wheels won't fit without full suspension stuff installed (at least on the 370z, haven't tried on the Z yet)
I didn't count lug nut rotations. Eyeballed a spot on the socket sleeve, where it was when the nut caught the first thread and after it was snug, which was about 3/8" diff. Although there seemed to be enough hub protruding to catch the wheel center, I suspect there wasn't. Going to do some fender measurements, remove all 4 and start over. Planning to remove one wheel, pop the center cap out, remount to see whether it's touching the hub. Wheels centers have a chamfer, and I should have measured that vs the hub protrusion before mounting.
Hindsight
I had a good 48 hours where I thought the 5mm spacers had quenched my thirst for spacers/fitment. NOW I'm back to swapping the studs and adding slip-on hubcentric spacers...mill extended studs to length (stock stud length + thickness of the spacer, then mill the rest off). IF I ever get to that point.
1. Ordered a catch can kit yesterday, and may configure some type of quick/easy drain line.
2. Undertray...leaning toward Z1, as the entire rear of the panel is removable, or moves out of the way. I prefer that over the removable cover on the CZP and Mishimoto trays. Ordered a used OEM NISMO undertray from Z1 (under $30), tried to make my own removable cover and screwed it up (the used one...never touched the one on my car).
3. Freakin' extended studs and spacers, I guess.
