- Joined
- Jul 21, 2024
- Threads
- 0
- Messages
- 509
- Reaction score
- 493
- Location
- California
- Car(s)
- 24'Z Performance, 67' Barracuda
I wish I had the money and time to mess around. I would buy a duel 2.5” with H pipe, duel 2.5 with X pipe, duel 2.5 merged into single 3” and then finally a full duel 3”. Then dyno all of them. Then I would test all of them with just lower down pipes and then also with full 3” down pipes.
I’m quite sure a lot of people would be surprised. There really is no need to argue or get upset. Everyone gets to make their own decision and spend their own money.
Couple things to point out though.
NA or supercharged vs. Turbo. Two different animals. In a turbo application the turbine is a giant restriction to exhaust flow. Apples to oranges. Also. In any application, the further down the exhaust pipe you go, the diameter matters less. This is due to the exhaust gasses cooling drastically as it travels down the exhaust pipes. Engine Masters tested this on a NA engine. Duel 3” vs a. y pipe into singe 3”. Didn’t matter if I remember correctly.
One thing is absolutely true is this. If you only have factory down pipes, it doesn’t matter at all. Next, if you keep factory upper down pipes and do catless lowers, then 3” is pointless. It won’t help make more power at all. Exhaust like the MBRP that is literally a 2.5” flange necked up to 3”. Again. The most important place to have the diameter opened up is right after the turbo. This isn’t an opinion.
