Suspension upgrades issues?
Go2ZZZ
Murdock
So, I just finished installing the following:
Z1front and rear sway bars (with endlinks)
Z1 toe arms
Z1 forged upper control arms
Z1 rear diff brace
Z1 rear subframe
Z1 collars
I expected better handling etc…
However, on my way home I felt the car to be pretty sketchy. Any small pot hole I feel it pulls me one way or another. It is a bit rainy night too.
I honestly felt more safe to go faster then when I put these “upgrades” on.
albeit, I haven’t gotten an alignment yet. Hope this fixes it cause when I got for my fast pulls I felt safe. I’m not sure I can do it with this suspension set up.
Is this normal? Cause I’m not feeling confident
jc604
@jc_rz34
canada
Take some time getting the upgrades broken in and a feel for ? Seems like u did a really big upgrade taking most stock suspension parts out. The alignment would also be an addition
Go2ZZZ
Go2ZZZ
Murdock
we’re about to find out as I’m going to do the alignment today. If I feel like it’s done nothing I’ll probably put my oem suspension back on. But hoping the alignment works
jc604
@jc_rz34
canada
I also will b upgrading but only springs n sway bars at the end of the month
Go2ZZZ
Go2ZZZ
Murdock
Just got back. Alignment was definitely an issue. Attached the report.
so far it’s better but haven’t really pushed it or went over any small bumps/potholes
Katum68
Mr Laurie
Nashua, NH
I have a 2024 Z Performance, is the NISMO suspension upgrade worth it? I understand about needing alignment.
Mr&Mrs
I'm curious about the Nismo suspension as well. Waiting for some reviews of it
Nismo suspension parts are currently being retooled. I would wait for the updated versions or go with another brand like Z1. I personally have most if not all the Z1 catalog and couldn't be happier. The R-Pro coilovers are true type and use FEAL struts and Swift springs.
MacCool
central Minnesota
2024 Performance Z
Indications are that Nissan didn't do well with at least some of the Nismo suspension parts for the RZ34. Z1 on the other hand has a pretty highly-regarded track record
Katum68
Mr Laurie
Nashua, NH
Great, thanks. I'll wait. No track days for me: i'm 79.
It was definitely alignment. Anytime you install suspension parts, alignment IS required. Toe is very sensitive at each corner, slight positive at rear stabilizes the car, make sure that's set. Better yet do a corner balance with you or your weight on the driver's seat and full tank of gas.
Hope all is fixed for you, those current measurements look good and Z1 upgrades are pretty high quality.
Wow. That was definitely the alignment. You shouldn't have any mistrust in those Nismo suspension parts as they are made by SPL. The majority of your problems was the rear toe!!
2024 Z
AG
San Francisco, CA
Marketing
2024 Z
AG
San Francisco, CA
Marketing
Hi there - do you have any intel on your comment about the NISMO suspension parts being "retooled"? I just installed the NISMO coilovers and they sound bad and the noise that I get from what sounds like a bad strut or tire wobble is bad. Nissan says all tests show things are normal and this is just a feature of the part.
2024 Z
AG
San Francisco, CA
Marketing
I just installed the NISMO coilovers on my 2024 Z Performance and hate them. The car handles well, but on rough roads, the sound of the tires not being connected to the road is bad. It sounds like a bad strut, but according to Nissan that is normal. I am about to put my stocks back on, its that bad.
