Stillen TruControl
Stillen says 70 bhp and 86 wtq, depending on altitude and fuel. Because they're in California, they ran these numbers using 91 octane, so expect a few more houses from 93.
House Power! A new unit of measure!
Nis Mo Z
Moses
Loganville, Georgia
service tech
I've been noticing a lot of TruControl and Hotbox owners who complain about issues with the engine performance and health on the FB forums. I think I know why this is happening.
Z1 and Stillen should've explained that in order to get great CONSISTENT performance from these units you NEED to have an upgraded Heat Exchanger!!
There's a reason I don't run Map7 on my car but now that I have the CZP Heat Exchanger I will give it a try. It works amazing with the mid maps(4/5) with the upgraded h/x in very humid 90+ degree F temps in Georgia.
And most of the people complaining of issues are those with the stock h/x during summer time horrific temperatures.
So to those that don't have issues what Map are you using? Do you have a upgraded h/x?
Tranzor Z
Banned
Banned
Banned
Nothing you posted is correct according to Stillen and their advertisement or video explaining this product. I have no mods besides exhaust. I've been on map 7 since 1200 miles and currently approaching 10k miles. No issues, no complaints.
Nis Mo Z
Moses
Loganville, Georgia
service tech
Are you on the FB forums? Do yourself a favor and check them out and you will see what I mean. You may be an anomaly but many people are complaining about issues using the unit, especially at Map 7. But think about it logically? If you're running more boost and power you will also need more COOLING to offset the increase in the other two. It's basic science.
Being in Houston, he is absolutely heat-soaking his heat exchanger. Heck, I was when bone stock before any mods at all.
Tranzor Z
Banned
Banned
Banned
What exactly are they saying or complaining about? I've been on map 7 for almost 9000 miles with no problems that I know of, in Houston, Mexico even.
ZULU-1
Doc
Z-Performance
Ok Gang!…. I’ll chime-in! Just let me set my walker aside and climb on the soap-box!
The operating temperature and cumulative effects of add-ons, including electronic mods deserve an in-depth analysis. It should be an individual choice as to how best protect your investment and the longevity of the VR30TTDD (Track, Autocross, Daily driving w spirited moments, Drifting, etc..) IMO, for long term reliability and peak performance, I suggest you invest time learning about options in lubrication (if not done so already,) …the impact on the overall areas of concern while considering intallation of specific mods, especially their effect on lubrication and temperature on Turbos. Enjoy the ongoing debate concerning Motul vs Amsoil and the new Gen of European synthetics. Compare the oil chemistry’s (formulation pros and cons on your specific mod set-up.... potential ill effects on each of your engine components. Again, should be a personal/ individual assessment on your engine. Not all factors are as critical for every engine set-up (bolt-on) and driving applications (your individual modifications started while driving at day-one, ie fuel selection, break-in parameters, etc.) For my engine (as a daily driver), the objective would be to minimize surprises, maximize performance, and extend the operational life as economically feasible; of course, while maintaining robust performance parameters.! I believe there is a "YouTube" video from an individual (with adequate credentials) that documents a comparison study on high-performance oils. I’ll see if I can find the link and post it at a later time; meanwhile, you could search for a tag with “Motul vs Amsoil” and perhaps the “Oil Guy” in the search line…. If I recall correctly, he compares 7 high-performance brand formulations using a high performance engine on a test bench/dyno setup.
Now......someone please help me down from the soap-box!
Enjoy…:like:
ZULU-1
Doc
Z-Performance
Oh …oh! I see how it seems that I have drifted (again) onto an irrelevant subject!!! Ok, let me sip on my Ensure Plus before depositing another 2 cents!
Well, basically what I’m alluding to in the previous post… is that regardless of what the mod appears to do for your engine set-up, one should consider the ultimate effect on operating temperatures…. Heat is the “Number One Enemy” and friction is inevitable on the engine’s moving parts. Each component should contribute to the overall performance in a positive manner (one would hope) nonetheless, there is always a negative effect (action/reaction law of physics) and the engine’s overall operating limiting factor is the HEAT! An engine may tolerate high temps to the design limits…. But it may also have a negative effect on the life cycles/ longevity of each critical component. Therefore, the cooling system, especially oil formulation is a paramount variable in the performance/health equation!!!
I believe that none of the Z owners in the forum, have a VR30DDTT that survived/surpassed 50K miles …. stock or otherwise! If so, please share your experience(s) and words of wisdom…. Lessons learned.
Thanks…
Hey! Who took my Ensure!!???:facepalm::curse::punch:
Nis Mo Z
Moses
Loganville, Georgia
service tech
They complain about weird throttle issue, the car sometimes having issues with starting after a drive, the engine overall acting weird. I saw one guy who said any Map above 4 or 5 causes the engine to feel horrible but I think that motor was heat soaked because he didn't have an upgraded h/x
Tranzor Z
Banned
Banned
Banned
Maybe they never had turbo cars? We all have turbo lag and when I go into boost this car is stupid fast. I walk V8s all day. Coyotes, scat packs, all of them.
I've never had a starting issue and honestly with almost 9000 miles on my Trucontrol, I should be a spokesperson for Stillen. My max PSI is about 19.5
I'm in Houston with a heat index of 115+ daily with zero issues. Heat soak and Mexican soak all day long!!!! LoL
Don't forget, people never go online to post anything positive about a product. It's always negative.
My oil temps are actually fair. I'm usually in the high 160s.
Don't judge a product that 1000 people have purchased and had success with based off 2 angry middle aged men on Viagra and Chinese testosterone.
Nis Mo Z
Moses
Loganville, Georgia
service tech
Like I said you've never experienced the issues or maybe you have but it's not a problem for you. It's not turbo lag. The big problem is the heat exchanger on the VR30 is massively underwhelming from the factory, especially in Spring/Summer. Basically what I'm saying is people who are tuned without the h/x upgrade will initially feel that extra power but after that soak sets in from a few pulls they'll be making less power than stock and it has nothing to do with Stillen/Z1 or ecu tuning.
I tried Map 7 before the h/x upgrade I did and initially I felt a difference but after a few pulls my Nismo felt like it lost a sizable amount of horsepower. Now when the temps were cooler(Fall) there was no issues with the Map 7 power outside of the lack of grip thanks to cold tires.
Tranzor Z
Banned
Banned
Banned
I'm not experiencing any of these. Boost is a crazy phenomenon. How many people are complaining about this? And why is this just coming to surface now after this device has been out for 3 years? You can't escape heat. I understand there are better items than Nissan to purchase but don't act like you're gonna be running 30 F degree air all day and night. I ran map 3 for like 10 minutes and went to 7 and never looked back. I don't know much about cars. Is it possible they are running 87 fuel? I'd love to get to the bottom of this or have Stillen chime in!
The 87-octane comment is a fair point. Social media is absolutely full of the lowest common denominator types that likely would try to save $15 by pumping in discounted grocery store regular. I actually remember a few of these types from my Evo days and it just made me cry in agony for the 4G63/4B11.
Nis Mo Z
Moses
Loganville, Georgia
service tech
So fellas I decided to do some in depth analysis on the Stillen TruControl unit. I called Jon, the tuner at Z1 and explained to him I that I want my Nismo dynoed with the B6A intake, Stillen Exhaust and CZP heat exchanger for stock-ish dyno purposes, then use the Stillen TruControl on Map 4,5,6,7 to see the gains and how each affects the timing, A/F ratio, Boost level, and everything associated with telling me which map is the most problematic to my engine. So this will be beneficial to the guys who have the exact mods I have. The CZP h/x plus the Nismo extra h/x can easily handle 5 runs on a dyno to show gradual progress.
