Splash Guards and Spare Tire
jayhawk70
Bob
gainfully unemployed.
One last point on this topic, the manual states that in changing a tire (by jacking up the car) you need to put wheel chocks on the diagonal wheel of the one you are changing (i.e. if the rear right is to be changed the front left must be chocked). I was just at Harbor Freight and they had heavy duty rubber chocks on sale for $4.99 apiece for club members (list $7.99.) so I picked up a pair. A word to the wise.
I actually had to use the 370Z spare that I added to my new 2023 Z. I just used the chocks from my 240Z... :D
Lots of old Z stuff remains useful!
Oh I've been debating adding the spare. This might push me to do it. What happened?
Once the spare is on the car, how much above the deck does the full-size stick up?
Finally, do the rear 007s stick any better with the spare and jack in the trunk ??
jayhawk70
Bob
The Tire Low pressure warning Display came as I was backing out of the garage. Found a screw at the edge of the tire area (rear tire). Mounted the spare and took it to the local Nissan dealer and my America's Tire dealer hoping they could just patch it. Nissan said tire was too worn on the edges (from apparent under inflated mileage). America's Tire said it was just outside of the tread repair area. Ordered an OEM stock replacement tire at America's tire as they were about $120 cheaper installed than Nissan.
The Tire Pressure dash display not only shows individual tire pressure, it also shows the correct inflation pressure for each tire (Performance trim: 32 psi for front tires, 29 for the rear tires).
The space saver spare fits completely in the depression left for the 370Z space saver spare. so the rear deck is still flat.
Oh Yes, the 007s with the extra 30 lbs in the rear makes the new Z AWESOME QUICK! Now I'm beating dual motor Tesla Plaids, Vettes, Ferrari's, Lamborghini's, even Don Garlits' Top Fuel dragsters!
(Just channeling Walter Mitty...):rolleyes:
I was asking more about placing the regular tire in the tire well area (while you're driving on the spare). The regular tire is probably much wider, so I'd expect it would stick up above the deck. Or maybe you wouldn't even place it in the well and just set it on top.
I knew it! Cost cutting killed the Z's advantage over these cars. ?
jayhawk70
Bob
The regular tire does not sit flat in the spare tire well because of its width. It cannot get under a lip at the back of the spare tire well. I placed it angled up from the spare tire well toward the front of the car. It does take up a lot of room but we were able to close the hatch.
If you are traveling with luggage, you might have a problem.
After the fact, I found out about the tire repair plug kits that would have worked in my case. Could plug the leak and pressurize the tire with the 2023Z air pump without using the sealant. (that I'm told could wreck the pressure monitor sensor in the tire).
https://www.amazon.com/Tire-Patch-P...3356117&sprefix=tire+worm,aps,159&sr=8-1&th=1
Now I have both the space saver spare and a tire repair kit in my 2023 Z. (the new Zs air pump and sealant are now in my 240Z with its 50 year old OEM spare tire...)
And of course I carry an Auto Club card!
Yeah, this was my concern. It seems like the main reason I'd want the spare is to avoid getting stuck in the middle of nowhere with a flat while on a road trip, and a road trip is when I'm most likely to have luggage.
My solution as well.
In town, you'll probably notice the issue before it becomes a real problem, and might be able to limp to a tire store to get it fixed.
It's nice that newer Nissans show each tire pressure individually on the cluster. Just keep that screen up on a road trip, you'd probably be able to detect a leak with plenty of time to get it looked at.
Wader
2023 Nissan Z, 2017 Nissan Navara, 2016 Subaru STI
I just did this on a 2023 Performance.
Get yourself a spare wheel from a 2015-2018 Q50 or 370Z Nismo. Make sure it's the 18x4 size. NOT THE 17".
Clears the Akebono's on the Performance.
You'll retain the bose system inside the spare and all your covers and foam will fit just as OE. Pick up a Jack kit from a 370Z or Q also.
Still don't understand why it wasn't there from the factory. Wieght savings or cost cutting?
Where did you find a black one. The dealer found a white one for me I believe from a 370z new. Is the black off an Infiniti. The wheel itself looks the same.
While I was at the dealer getting my bumper recall fixed, I almost pulled the trigger on ordering a spare and a jack. I just couldn't convince myself.
I keep thinking the place where I'd want a spare the most is in a road trip where you're miles from help. But if I'm on a road trip, the hatch is probably full of luggage.
If you put your spare on and then try to put the full-size tire in the well, it's just not going to work. The well is maybe 7.5 inches deep.
And the full-size rear tires is maybe 11 inches wide. It's just not going in there without stealing 4 inches of hatch depth. It might fit, but your luggage won't.
I think this is the key. Watch the tire pressure, and get it fixed before it becomes a problem.
oxtopheryames
Lexington, SC
2023 Nissan Z
IT Infrastructure Network Operations Specialist
18x4 for the performance? The Z performance has 19 inch wheels. Would that work?
I don't hate the splash guards and I thought about getting some. But for the money I will probably pass.
I agree on skipping the spare tire. I was all excited seeing how people were getting one in the trunk but then it hit me, what if you actually have to use it? I think you nailed it @bpeckham - does not seem feasible on a road trip with luggage, which for me and apparently others would be the reasons to try and make one work. The OE tire(s) / wheel(s) are no bueno in the trunk.
Ramman
SC
engineer
II have the 2023 performance Z and have done all the above. My question is the base speaker now sitting in the tire does not seem to be functional. Is there a way I can test it? My previous Z was the 300zx and the Bose speakers were really good. So far I'm not impressed with the one in the car/tire.
Interesting question.
This thread has a video that shows how to enter the secret menu on our Zs.
Poking around in there, I found a speaker test menu item.
However, there does not seem to be a way to test the sub. ?
