Splash Guards and Spare Tire
Laze1
John
Atlanta GA
2023 Nissan Z
I just purchase and installed this "universal spare" in the rear on my Performance model. I also test fitted he spare on the front wheel and if fit...a little tight clearance to the caliper, but would likely never be a issue. Also the big Sub fits fine back into the spare as designed. Note: I did remove most all of the original foam. BTW: I purchase a OEM jack kit and it works fine as well, and is stored in the rear with the tire. https://modernspare.com/
Ramman
Richard
SC
2023 Z
engineer
OK I give up. Can you repeat the sequence on line here that you went through to get to that menu. The link you referenced does not work on the 2023 z pro (as I'm sure you realized). THANKS
