Shifting into 2nd? (Manual)
Who.Am.Eye.2716
I have a 2024, build date Aug 2023. 2nd gear sucks donkey balls. When its cold, its hard to shift into 2nd between 2k-2.5k rpms. When the trans is warmed up, its still hard to shift into 2nd gear at times.
Anyone else having issues?
Bert
Melbourne Australia
Mk7 GTI performance
Definitely doesn’t like being rushed from first to second but give it time, and it should loosen up a bit
MacCool
Mac
central Minnesota
2024 Performance Z, GMC2500HD (winter), others
My 2024 is an AT, but until this car I've had two 370Z MT's since 2011. The second gear "notchiness" is well known (along with the crappy plastic clutch cylinder). Sounds like they're using the same MT transmission design in the current Z's. Hopefully they addressed the clutch issue. Twelve years driving that "meh" manual transmission is one reason I didn't really care that my dealer could only come up with an AT for my 2024.
Mr&Mrs
I currently have an AT but as @MacCool mentioned, it was a known annoyance with 370z's. I do not know if they are still around or make them but a company called RJM made an adjustable clutch pedal that completely solved the issue. I had it for my 370z.
MacCool
Mac
central Minnesota
I really toyed with getting the RJM pedal for my 370Z but never pulled the trigger. I wanted that pedal because of the quirky/weird manual clutch engagement geometry. I always found the 370Z MT to be a difficult car to drive smoothly. My wife is very experienced and competent with manual transmissions but it was even harder for her and she really never wanted to drive the car. Now, with a 400hp AT, she wants to drive the Z much more often, so....AT has been a blessing and a curse for me.
The ostensibly frequent clutch cylinder failure was a separate issue. I never had that problem in over 70,000 miles and 12 years with 370Z's, but reading over on The 370Z forums, you would gave thought that it happened to every car without fail.
Ramman
Richard
SC
2023 Z
engineer
I've got the 2023 Performance Z and have had it for about 6 months. Down shifting into 2nd has never been a problem. Up shifting is a bit stiff but still not a big issue for me. I had the 300Zx and loved it. I really LOVE this Z. In variably at least once a drive I'll somehow stall it out. That however usually occurs in the combination of clutching from start and first gear (not second) and seems more because I'm at a traffic light and feel pressed to move out .
TheRoyalStig
Nj
When it's really cold and it's still warming up I double clutch into second and it makes it go very smoothly.
In normal driving it goes much smoother into 2nd at 4k so that's where I shift when possible.
When going slower and needing to stay at low RPM I just make the shift extra slow. My sorta go-to trick that has become second nature at this point is letting the shifter pop fully into neutral before moving it into second. That causes enough delay to make things go much smoother.
Just gotta figure out the little idiosyncracies and work with them.
Brock
Brock
Oklahoma
Nissan 370z
I have a 2023 Performance model, and have had zero issues with 1st to 2nd or 2nd to 1st. Guess I’m lucky 😊
  • Like
Reactions: KCZ
Jah_Happy
Same, nothing has stood out to me while shifting. Even in the Northeast haha.
Who.Am.Eye.2716
Who.Am.Eye.2716
Im going to look into the z1 clutch kit. Maybe change the trans fluid to Redline while im there. Thoughts?
This morning, I started shifting slower from 1st to 2nd and seems to do the trick. I also let the rpm's hang for a bit before pressing in the clutch pedal and shift from 1st to 2nd and seems to go into 2nd more smoothly than slow shifting.
Learning shift points and when to shift seems to be a chore lol
Fanatic
Sonny
Plano, Texas
Hospitality Management
First to second can always be a little sensitive on manual transmission cars. Just have to make sure you are more delicate and also pushing the clutch all the way down before shifting to second.
Who.Am.Eye.2716
Who.Am.Eye.2716
Must be a Nissan thang 🤷🏽‍♂️
This is my 1st Nissan that I have owned
Older BMW's, Toyota's, Acura's didnt have such issues going from 1st to 2nd
Fanatic
Sonny
Plano, Texas
My older BMW E90 M3 had it. My Civic type R'S have it. My mustang GT had it. One car that did not have it as much was my previous Subaru BRZ.
