VR Forged D03-R Z Fitment
19x9.5 +22mm 5x114.3
19x10.5 +22mm 5x114.3
Looking back at these, very good fitment and offsets. I think will look and pop nicely on Solid Red, thoughts? I've always liked the NT03+Ms although these types are a bit of a pain to clean.
When you have the back tires with a 30 sidewall, do you see more of a gap between the tire and the fender?
I am having a hard time finding the tire size with a 35 sidewall for the rears. I might have to buy the rears with a 30 sidewall like yours. I am looking at this set of tires:
265/35ZR19 - Fronts
305/30ZR19 - Rears
what size are you looking for? michelin pss has many sizes including 305/35/19
Nismo LM RS1 Bronze
9.5 fronts +12 offset wrapped in Kuhmo
10.5 rears +12 offset wrapped in Michelin
Yep, +12 looks to fit best at the rear, nicely flush. I've been checking out VR's offerings. At the front though, it looks more tricky, any clearance issues, turning, etc?
What are your thoughts on Solid Red with the Proto Spec bronze wheels? Any here sporting them or similar red on bronze? Thanks appreciate it.
VR30Z6spd
Sultan
KSA
Z 6spd
initially i was looking for the proto wheels but for the price and offset you cant beat the nismo
offset and drop is perfect
i think in the future i can go 295 rear easy
VR30Z6spd
Sultan
KSA
Z 6spd
nothing at all. i can go 295 next time and still wont rub
Landon
Landon
United States
19x10 ET27 (23.9lbs)
275/35 PS4s
19x11 ET25 (24.4lbs)
315/30 PS4s
Variant Aure
Maricopa Copper w/ Frosted clear
Did you use the Swift Spec-R Lowering Springs 1.1"? Did you lower your Z in other ways?
10mm would poke, its about 2-3mm from flush
That's very good fitment for those widths and offsets, and no need for spacers. What about camber settings? No rub anywhere but added some negative camber? Looks not even aggressive on the lowered Swifts.
