Exquisite_Red
- First Name
- Donnie
- Joined
- Feb 24, 2025
- Threads
- 2
- Messages
- 122
- Reaction score
- 198
- Location
- Nashville, TN
- Car(s)
- '24 Nissan Z 6MT
- Occupation
- NNA-S Project Manager
- Thread starter
- #1
Anybody else experiencing this? Conventional wisdom is that we should let the oil warm up to at least 170° before heavy throttle. However, my oil temps will not reach that point, regardless of driving conditions, city or highway.
Ambient temps have been low, so that’s obviously a contributing factor, but still seems odd the car will NEVER warm up. I coddled the engine prior to the break-in oil change at ~1,500 miles, so I’m not actually sure if this was happening prior to then because I wasn’t really monitoring oil temps as closely. I installed a Z1 under shroud at the same time as the first change. I went with the Z1 because I thought it had the best oil cooler flow vs. other options (and especially over the stock shield). But could the oil cooler now be working TOO well??? It seems silly to blame this on a shroud, but that is the only change point.
I put some examples below, but the TLDR is that I can’t get above ~150-160°. Last night it was pegged at 159° at 44° ambient, but I said screw it and did a couple WOT pulls through 2nd and a little of 3rd and it still only went up a couple of degrees before quickly settling back down to where it was. Is there possibly a thermostat that controls flow to the oil cooler that has failed? Or does the oil always go through it?
Anyone else having trouble getting the oil to warm up?
After about 30 mins on interstate driving, pegged at 154°:
40 miles of 73-78mph interstate driving later, temp down a couple degrees:
A few miles later, after taking an exit ramp and cruising at 60mph, another few degrees lower:
Last night after ~25 mins of city driving, higher ambient temp, still pegged at 159°:
