- Joined
- Jul 21, 2024
- Threads
- 0
- Messages
- 538
- Reaction score
- 524
- Location
- California
- Car(s)
- 24'Z Performance, 67' Barracuda
Because plane engines don’t have oil filters a lot of times?
Drain engine.Hmmm…
Yes. There are ex-spurts, then there's experts.This is exactly why pilots pay actual certified mechanics to perform and document maintenance logs.
Googled the part #. Added "specifications", or "bypass PSI" after the part #Where did you get the info on the relief bypass spec for each oil filter? I've been sent an oil filter with part number 15208-9F60A but want to see if it's at least the same spec as the 15208-65F1E I ordered
They claim it's for the turbos, but you absolutely could be on to something! Easier to explain away turbos than a suspect or flawed solenoid...Just had a thought:
What if Nissan is recommending the F1B, F1E filters with the high bypass pressure so that there is less garf and crap to clog the oil solenoid?
A bit of bypass isn't bad. Eventually, all oil will pass through the elements. Under normal conditions, we aren't adding particulate, shrapnel, etc to our oil.
