OEM Wireless Charger
Murix
SF Bay Area
I have been using the motorola wireless android auto adapter for a couple of years now in my other car along with aftermarket wireless charging. It works but it is not perfect. The occasional reboot, slow reponse, and sometimes I just need to plug it in to charge. I would rather a discrete setup. Plugging in a cable is more reliable, faster charging, and pretty simple.
HWill
HW
Arizona
2025 Nissan Z Performance
Main issue is when you combine wireless Android Auto / Carplay with wireless charging. Both are demanding
No, the main issue is the charger overheating the phone. Using AA/Carplay while charging with them just makes it worse.
Commonsense that running an app while charging will create more heat but should be within heat specs to not cause damage.
weissk93
Detroit, MI
That doesn't look bad. This may be the play. Does it work well?
Edit: When I look it up only comes in as "Used". Any new ones?
I bought it and returning. It came used even though it said new. Also, not ideal when phone is moving around while driving. Need something with magnet.
Not sure how much of a problem it is, but the 2027 has a charging indicator in front of the shifter. The OEM panel where the charger is does go underneath the shifter panel, but I don't know if the light is mounted to the cubbyhole panel and sticks through the shifter panel, or it it's mounted to the shifter panel. If you're not concerned with the light I assume retrofit wouldn't be terrible. And maybe the light isn't a big deal to retrofit. Although pulling all of that apart and reassembling could create squeaks and rattles that could outweigh the convenience of having the charger there (my opinion).
The ebay charger/insert this thread was started with does have a charging light that's in the panel itself...but that part is not OEM Nissan, which could be a dealbreaker for some. Looks good to me, but $300 ?!
Not on my radar at this point for me, but it would be nice to get the info from the charger itself in that ebay link. I think it would be fairly simple to add in to the existing cubby, attaching from underneath, but you'd have to cut a hole in the panel and the mat.
HarryBo
Barry
'24 Z Nismo
This slim charger from Amazon fits nicely and charges well, $18
That looks great! Wish I could get one here in Canada. Amazon Canada doesn't show it. Fudge!
Good find. U not using a wireless USB stick? Add one to complete your set up.
wsuZ
Northern Hemisphere
'25 Nissan Z
I bought a magsafe charger from Apple and have it tacked to the OEM rubber mat. Works great to stabilize the phone but sometimes pulls the mat when lifting off the magsafe base. Annoying but tolerable.
I may buy a second rubber mat, cut a hole for the charger, and tack the magsafe directly to the console.
finizzle
AJ
2024 Nissan Z Performance Brilliant Silver M/T
Software Engineer
I’d be interested in finding the OEM part and what it takes to install. I ALWAYS put my phone in that spot so having it charge while sitting there would be nice.
Did anyone ever find / install the OEM part for this?
finizzle
AJ
Software Engineer
I’ve been meaning to learn some CAD / 3D printing so might play around with making my own replacement soon. I don’t care about the wireless charger part but it would be nice to have a phone magnet and a place to put a quarter (my Aldi quarter slid away somewhere under the seat the other day, so it seems like just sitting on the mat isn’t enough for spirited driving)
If anyone has other ideas on what to add to this let me know
finizzle
AJ
Software Engineer
traska_rz34
Liam
Cocoa Beach, FL
I found the part number 28342-1YE1A but I’m not 100% sure that it’s the same one from the image
Haha, I literally pulled up the exact same part number but I agree that it’s impossible to know if it’s the same as the one in the pic given that no part sites show what it actually looks like. Plus, no clue if this plugs and plays or not. For ~$400, that’s a steep investment to find out.
_ds_
North Carolina
2026 Z Performance
I printed a little holder for my Aldi quarters that locks into place the center console. I print the Aldi quarters out as well and take a few with me and hand them out to people that need them when I go to Aldi.
