Nissan Z: Replacing Gas Pedal
Landon
Landon
United States
KyleWI
Kyle
Wisconsin
24 Z Performance MT
Disconnect the battery (-)
Unclip the connector at the top.
Remove the plastic rectangular trim at the base of the pedal.
Remove the two bolts.
Disconnect the connector at the rear.
I don't see anything else.
Landon
Landon
United States
Will there be an error code warning once I reconnect the connector?
SleepyD7
Gainesville Florida
Audio Video Integration Sales
Disconnecting the car battery before you unplug the gas pedal will prevent the computer from detecting the disconnect. The two bolts are 10MM btw.
Landon
Landon
United States
Do I need to disconnect the + and - from the batter?
Landon
Landon
United States
Just the negative side. No need to touch the positive side.
Here is a picture of the gas pedal with 2 red arrows to make sure I am looking at the right locations.
How do I pop out the little plastic knob at the top red arrow? Can I push it in with my thumb or use a hammer to pound it in? Thanks!
ā€˜25 PRFM M/T Gun Metallic
It was only mentioned 5 times in 4 sentences, so are we certain he's asking specifically about his Gas Pedal?
@Landon, just curious what's going on with it?
...your Gas Pedal, I mean. And why you need to remove or replace your Gas Pedal. I've never had a Gas Pedal problem in a modern car. Curious what Gas Pedal-related issues can happen to a Gas Pedal that would warrant removal or replacement of a Gas Pedal. :wink:ā¤
Seriously though, I'm curious what happened.
Landon
Landon
United States
My gas pedal seems to be unresponsive sometimes and I was told by Nissan to replace the gas pedal. Also, I want to replace it with the metal style gas pedal anyway. This metal gas pedal:
https://www.z1motorsports.com/accel...rator-pedal-assembly-performance-p-36128.html
SleepyD7
Gainesville Florida
Shinier yes! More responsive? Negative. Seeking more power is natural; your journey has begun. Just remember; great power comes with great… well you know the rest. Hopefully
When you say, ā€œI was told by Nissan to replace the gas pedalā€ was that during a visit or over the phone? If so, is your warranty gone? If the problem is the pedal, it should be repaired under warranty.
Good luck. Let us know I’f replacing it fixes the issue.
You going to need bigger shoes for that new pedal…
you can use your ecutek app to monitor and\or datalog the throttle position sensor…
