Cold Weather Oil Temps
MrDuke5012
Jerod
DMV
2026 Nissan Z Sport
Hey guys,
Seeing if any other Z owners in colder areas are experiencing this. Basically, the oil temp is struggling to reach normal temps, especially now that it’s getting colder outside.
I try to let the oil temp get to 170F before I start spirited driving based on what I’ve read on the Racebox website. However, even after driving for 30 mins, the oil temp is barely getting to 160F.
I live on the east coast in the States and now that weather is consistently in the 40Fs my Z is almost never going to get to above 170F.
Should I assume this is normal in cold weather? Or is there maybe an issue with the thermostat? I just hit 7,500 miles so I’m still under warranty.
Thanks in advance.
Perfectly normal, my oil temps are settling out in the 150's here with current ambient temps in the 30-50's. Oil is ready to party once it hits 150F...heck the C8 Z06 oil temps sit in the upper-130's during these ambient temps!
Cold weather performance is one of the benefits of the factory 0W-20 engine oil.
MrDuke5012
Jerod
DMV
2026 Nissan Z Sport
Sweet, thanks for the info! I’m currently running 5W-30 so maybe I’ll switch to 0W-20 to see if that helps too.
Thinner oil will warm up more quickly and flow/protect better at lower temps.
I know people love playing with oil viscosity, and this is a huge debate on the Jeep forums too (Pentastar V6 also specifies 0W-20), and there's a very interesting thread on wear metals, etc. comparing 0W-20 vs. 5W-30 oil analysis results. Long story short, 0W-20 showed less start-up wear with no meaningful benefits found from switching to 5W-30 as long as oil change intervals were performed on time (i.e. factory spec or sooner) prior to shearing down. Again, different engine, but interesting none-the-less.
I personally would not run a turbocharged application to 10k mile intervals, but seems like most of us are changing our oil at least every 5k or more frequently anyway.
As info, and this is just me personally, but I have all 3 of my vehicles running 0W-20 per factory spec with no plans to change that.
Zplz
Dave
2025 Z Sport AT, Lexus ES350
For me, changing the oil at 5k, 6mo., or sooner has always been good insurance. With the dozens of vehicles I’ve owned over the decades, I’ve never had any oil-related issues, from Fiats to Nissans to Toyotas, and everything in between.
zeroptzero
Joey
Ontario
26 Z
when you reach that temp range start pushing the engine with more load, but keep the rpms down a bit until temps go up further, you should see temps increase as you put more load - boost. The oil coolers work better in cold temps
Or do like my old college roommate... Dead of Minnesota winter, would get angry at how long it took to get heat from his Ford Explorer. Would do a cold start and immediately floor it and let it bounce off the rev-limter. The good news is, he got heat very quickly!
Koryak
John
Colorado
retired telecom instructor
I'm pretty sure all Zs come with an oil to engine coolant heat exchanger as apposed to oil to air. The 0W-20 is going to circulate fast and pick up heat from the coolant. My oil temp starts out below the coolant then after 7 - 10 miles exceeds it settling around 190 - 200 F. I keep the revs up shifting the 6 speed manual around 4 K even in cold weather. This was Porsche's recommendation even with thick straight weight oil in their air cooled engines during winter :)
  • Like
Reactions: G M
zeroptzero
Joey
Ontario
26 Z
Back in 2016 Honda had a direct injection turbo motor that refused to heat up, needless to say it added tons of moisture and fuel into the oil sump. For some strange reason Honda created a motor that wasn't expected to be driven in short distance city driving and during cold weather conditions, lmao. CRV owners couldn't get any heat out of those motors in winter, it was crazy.
Skytow
‘24 6MT Performance Z
Mine is the same. 40 to 50F outside and I’m seeing oil temperatures in the mid 150s to barely 160 after 40 minutes of steady driving. I too was looking to see 170 before getting over 3000 rpm but I’ll never get there if I wait for 170 oil temps!
The Z has an oil-to-air engine oil cooler.
Mitchb
Mitch
New York
2026 Nissan Z Sport
With the ambient temperatures falling in the range of 40 - 50 F, my oil temp stabilizes around 175F. I do not know where the oil temp sensor is located, but I am going to tape over the cooler to block air flow to it and then reassess.
Koryak
John
Colorado
@Mitchb - I'd guess the sensor is in the oil pan which is almost universal. Actual bearing oil temps are higher which is why you can boil off condensation at 175 F.
Koryak
John
Colorado
Ah ha, maybe owners are seeing differences in oil thermostat regulation assuming Nissan fits one. I've used cardboard to block oil cooler air flow on other cars when there isn't good regulation to keep oil temp up on cold days.
Hey guys,
Thanks in advance.
what’s your oil pressure at these temps? hot summer idle is -22psi, attached photo is this morning after -5 miles maybe 10min. oil temp was 183F after 35 mile highway run
