Cold Weather Oil Temps
MrDuke5012
Jerod
DMV
2026 Nissan Z Sport
Mine is the same. 40 to 50F outside and I’m seeing oil temperatures in the mid 150s to barely 160 after 40 minutes of steady driving. I too was looking to see 170 before getting over 3000 rpm but I’ll never get there if I wait for 170 oil temps!
Yeah I guess Racebox sees higher temps down in Houston. I’ll be dealing with single digit outside temps in a few months where I’m at and I’m not able to store my Z away in the garage during the winter.
After I installed the CZP oil pan, I noticed a drop in cold weather temps.
The aluminum pans do a good job dissipating heat, I noticed the same when I installed my Dorman.
I also trimmed open my plastic engine undershroud +25%, and even when I lived in Houston during brutal summer traffic my oil remained steady in the 170's thanks to these two things.
I suspect RaceBox chose the 170F mark b/c of some of these reasons, and decided to consider that as fully warmed up. More of a loose indicator rather than a technical specification.
jacksonmagnet
ny
z
jacksonmagnet
ny
z
Also when I get to about 150ish my boost target multiplier is at 100%, as far as I know that means it’s ok to drive on, I try to wait till 170f to get rowdy tho
phil_chronicles
Sweet, thanks for the info! I’m currently running 5W-30 so maybe I’ll switch to 0W-20 to see if that helps too.
That 5w is fine unless you live in northern countries where outside temps hit below -20°F, there is no benefit using 0w.
Yep, I read the brochure 😆
EDIT: Just read that you're in the area with single digit temps. I'd switch to 0w in the winter, and 5w in the summer
MrDuke5012
Jerod
DMV
2026 Nissan Z Sport
Yeah I’m going to do this pretty soon!
