Aluminum Oil Pans (Z1 vs. CZP)
I've learned (the hard way) that when it comes to aluminum bolts, "feel" is the best torque setting. Use the wrist then a final 1/8 to 1/4 turn elbow torque.
aurora rz34
Brock
Pennsylvania
2026 nisaan z heritage edtion
I didn’t read through all 7 pages but if no one has mentioned it so far I just installed the doorman metal oil pan on my 26 heritage edition and it’s a fraction of the cost of the z1 I got it on rock auto for $170 ish and it seems like it’s a great part comes with the new gasket and everything just make sure to use a different drain plug than the one that comes in it I used a gold plug.
The Dorman is a quality pan and what I also installed. Nothing wrong with their supplied magnetic drain plug.
I have a magnetic plug (Z1, I think) but curious what @aurora rz34 issue is with the Dorman.
Is it time for another bypass rating conversation? :inlove:
aurora rz34
Brock
Pennsylvania
I already had decided to change out the plug before I even ordered the pan but when I received it the magnet was just loose inside the plug the only thing holding it in was the plug itself being magnetic I could just lightly pull and the magnetic would come out. Also the magnet in the gold plug is far stronger than the dorman one
Oh that's not good! Luckily mine was solid.
Yikes! Not good!!!
Type "bypass" in search here and see what you get. For some reason it's a topic we like to discuss ad nauseum, and nauseum, and more nauseum. Brought it up here sort of tongue-in-cheek, but it's kind of like bringing up veganism around a vegan. Best to keep your mouth shut.
In short, my opinion and others may disagree... The Purolater filter you're running likely has a bypass pressure around 15, where the recommendation for the Z (or VR30) is around 30. If you change your oil and filter regularly, a filter with a lower bypass rating isn't going to cause any harm whatsoever.
aurora rz34
Brock
Pennsylvania
Yikes! Not good!!!
I always do 3k mile oil changes even though I really don’t have to it just makes me happy knowing the oil I have In my car is as fresh as possible
jliuod
Perfect timing. I just did my first oil change at 1K miles. While I was at it I changed out the ABS oil pan with a Dorman oil pan and also replaced the oil solenoid with a JR oil solenoid block off plate. Pretty easy to remove and install. It also comes with a dummy plug for the stock harness. Took it for a drive and everything is good. No leak and no check engine light.
