Why are Nismo seats designed with no pull to access the rear cubbies???
Imperial
Southern California
2023 Pathfinder Rock Creek, 2024 Z Nismo
I have taken advantage of having "manually adjusting seats" in my Nismo. According to my DL, I'm 5'8. But since I keep getting older 🤣 I'm probably shorter now. The thing is that every time I would get in or out of the car, I would kick the door panel at the bottom of the speaker. Already messing up the finish.
I've found the perfect solution. A simple pull of the lever and the sit goes all the way back. Now I have perfect clearance. Once I go in to drive it, I just pull a few notches and I'm set.
On my previous Performance model, I wouldn't be able to do that because the seats are electric.
Now my door panel is nice and clear. 🙌🏻
I've been doing this since my 370Z Nismo that it's become 2nd nature. It a good way to prevent scuffs to the bottom of the steering wheel as well.
alienpoker
Richard
Fresno, CA
2025 Z Nismo, 370Z Nismo
And the wearing of the side of the seat bolster, if you have it long enough. Yeah, a 2010 370Z Nismo owner…
At a little under a year old, my shoulder bolster is already showing wear where I hook my elbow to lever myself out.
funnyman850
funnyman850
Justin
Boston
instagram.com
'25 Z Nismo
My M4 suffered this same fate. I found supporting your weight on the doorsill helps a bit. Still awkward to get out though
I'll try that!
I've switched to elbow against the B pillar up by the back window, but it's a bit of a stretch.
