Meg_Z
Yes those will be my tires of choice for now on.Same. My god, are they superior.
I've had such good luck with PS4S, it'd be hard to switch away, but maybe I'll try these for my next set. So many rave reviews here.Yes those will be my tires of choice for now on.
Day 1 I replaced those oem tires with Michelin A/S Pilot Sports 4.It cannot be understated how awful the S007's are. 13,000~ miles on my 2024 and I'm about to pull the trigger on some PS4S. Factory size up front, 10mm wider in the rear to help with the lack of traction. I'm hoping between better and wider tires I'll be fine.
I had R/T Tuning put in 5w-40 full syn Liquid Moly. Next one im going Motul 5W-30 for fall season. My oil pressure at idle is at lowest 23psi. 0w-20 it was 16psi. Race Box put up a bulletin about addressing low oil pressure and making at most 5,000 miles oil and filter replacement. I do 3,000 miles . I'm old school. My money and time so I do it.Good readings over all, Scott, mixture of track and street miles. What 5W30 are you using? It's working well. Viscosity did get thinned out a bit but still good protection. I wonder if 5W40 could help, not sure what temps you come across on your track days. I use 5W40 LiquiMoly on my Cayman S for our hot climes here, good success so far.
Is adding an LSD to a Sport worthwhile? Mine is automatic and i just kinda never turn off traction control.I still break the @$$ end loose even with the new rubber and a LSD.
Over 25k and no issues. I've been diligent about oil changes and gonna put in stainless steel brake lines when I flush that fluid soon.
Is adding an LSD to a Sport worthwhile? Mine is automatic and i just kinda never turn off traction control.![]()
Dude what’s the deal with those codes? The parts I want are not in stock but vary per store but are completely sold out for exampleWhen you drive it HARD 0.05% of the time, and using the paddle shifters? Those times? Yes. IMO, the other 99.95% of the time in an automatic is a no from me.
Sorry. I'm only a fan of automatics in a sports car 0.05% of the time. My true opinion will earn me a time-out.
If you do decide to so the swap, it is dead simple with a lift and a tranny jack. Keep an eye on nissanusa.com for a coupon code. Be choosy about the dealership if goes to, as it affects the price. (Empire Nissan was just under $2k. Rt17 Nissan was $2600. BOTH were "15% off")
NissanUSA parts are hit or miss. The AT muffler, for example, has been sold out for some time.Dude what’s the deal with those codes? The parts I want are not in stock but vary per store but are completely sold out for exampleit’s confusing, the max I found was 25% and intakes that’s a huge discount
So technically speaking can we also use the dealer’s service department to order parts that are out of stock or discounted? I’m just curiousNissanUSA parts are hit or miss. The AT muffler, for example, has been sold out for some time.
The coupon codes come and go. What did NOT change, however, was which dealerships had the lowest price on the Z Performance 6MT rear diff (LSD). Empire Nissan was always the lowest. When the coupon code came up, it made the price even lower. Empire wasn't out the $; Nissan was, as I bought the LSD from Nissan.
Take into account wider rears will create more understeer too though. I was really surprised how much it had once you throw it at a race track.It cannot be understated how awful the S007's are. 13,000~ miles on my 2024 and I'm about to pull the trigger on some PS4S. Factory size up front, 10mm wider in the rear to help with the lack of traction. I'm hoping between better and wider tires I'll be fine.
It’s annoying how they put the average column on the wrong side of the table. It should either be first or always one column to the right of the analysis column.Z Nismo with around 31,500 miles, multiple track days and aftermarket mods like intercoolers, lower down pipe, exhaust, etc (no tune). Just got my first oil analysis back from Blackstone Labs and seems like everything is humming along!
s![]()
I purchased the only one in USA. I called a few dealerships in my area and one dealer told me there was only one in the USA. same guy told me to take mine to a muffler shop and have it fixed. Lol.NissanUSA parts are hit or miss. The AT muffler, for example, has been sold out for some time.
