Torque Wrench
Landon
Landon
United States
I recently bought a torque wrench and need advice on correct setting for the Z.
Some YouTuber videos are recommending 100in - lb. for all 4 wheels by using the torque wrench.
Here is the setting for 100 foot pounds:
Eizrael
Seattle
2026 Z Heritage
I've seen some varying numbers based on different wheels and/or makes and manufacturers. But theyve always been between 80-110 FT-LBs. 100 ft-lb is a solid rule of thumb if you don't have the actual spec. the owners manuals in the new Z doesn't actually list a specific number but the prior gens were all on the lower side of 85 or so.
80 ft-lbs
Make you're you're using the correct scale i.e. not inches!
2Cool
Ian
I normally hit 90-92 ft/lbs. OE lug studs are normally grade 10.9, which for a M12 x 1.25 thread pitch is rated for 100-110. I see no reason to max out the stud torque rating.
ā€˜25 PRFM M/T
anyone use a torque stick?
ā€˜25 PRFM M/T
80-100 shouldn’t be a problem, I would be more concerned with the rotors from uneven torque and incorrect torque pattern….
my taco is 83 so 80 should be plenty for this little grocery getter - lol
phil_chronicles
i just use a socket with an extension
I do 90 ft lbs on all my cars. No rotor warping from over torque.
ā€˜25 PRFM M/T
ā€˜25 PRFM M/T
How reliable is the torque stick? Is it safe and accurate to use? Don't want the wheels to fall off while driving on the highway. LOL!
Never used one - going to order one and use with my impact wrench, then follow-up with a torque wrench to verify it works.
FatRatZ
No, because they only work with power, air, or electric, wrenches. They need the high speed of a power wrench to get the shaft to flex to let you know that the torque point has been reached. With a hand wrench, you won’t be able to get it to work. I’ll For me anyway, it’s easier just to use a regular socket with a torque wrench. Although frankly, most of the time I just do it by feel.
ā€˜25 PRFM M/T
I will use it with an impact wrench. My thoughts was to then verify with a torque wrench….
ā€˜25 PRFM M/T
A proper torque wrench from Harbor Freight is like $20.
Not concerned with cost. i have torque wrenches…. I like the idea of using a torque stick.. my orginal post was asking if anyone has experience?
here are a couple of more options
