- Joined
- Jul 21, 2024
- Threads
- 0
- Messages
- 518
- Reaction score
- 504
- Location
- California
- Car(s)
- 24'Z Performance, 67' Barracuda
Just chiming in to hopefully help a little. There are a couple of things at play here when speaking of “larger brakes”.
1. The larger the rotor is compared to another, creates a larger lever arm. It is not just heat management. The larger the lever arm (greater distance from the center of the wheel to the caliper pressure point) the more stopping power for a given clamping force. So you can have greater ability to stop the spinning momentum with the same given caliper.
2. Clamping force of a given caliper. Meaning, you could have two setups with the same size rotor and same density/mass (which are equal in heat management) BUT, have one with greater force thus having a higher ability to stop the momentum.
3. The amount of pots help with equaling the pressure across the brake pad causing a given pad to do its best based on even pressure distribution.
4. You could have a caliper with the same force clamping a rotor that is the same size and mass, however, have the design cover more of the rotor bringing more friction to the equation.
This would all be assuming that everything else is equal. Tires, fluid, brake lines, alignment, and the nut behind the wheel.
My point? Blanket statements about what does or doesn’t do a better job isn’t fair to the debate. Also, personal attacks help no one. We’re on the same team here.
