- First Name
- Chad
- Joined
- Feb 23, 2025
- Threads
- 44
- Messages
- 1,597
- Reaction score
- 1,988
- Location
- Tallahassee, FL
- Car(s)
- ‘24 Z NISMO
Do you have to remove all that crap (AT oil cooler?) just to unplug the connector?
The videos I have seen for the 9AT cars show it being removed. It would be RIGHT in the way.Do you have to remove all that crap (AT oil cooler?) just to unplug the connector?
lol!…a fix without a coin?!? Maybe you didn’t NEED to use a coin, but SURELY you could have found a way to work a nickel or two in there somewhere!The videos I have seen for the 9AT cars show it being removed. It would be RIGHT in the way.
Even on my 6MT, I had to contort my hand to get the tab flipped up.
I plugged in the 25 ohm, 2 watt resistor today. Taped over it, and zip tied it to the nearby wire. Cleared the code.
No codes or smoke on the way home. And, I didn't need to use a coin!
Thank you Sir, I am sticking to a 5k to 6k mile interval (as required for the warranty)Not sure how prevalent it is on later VR30s, but the reason it fails is contaminates jamming the solenoid. The best thing you can do is change your oil regularly.
4-5k is ideal for a turbocharged engine in my opinion, but plenty of debate surrounding the matter.Thank you Sir, I am sticking to a 5k to 6k mile interval (as required for the warranty)
I daily this baby, monitor the oil temps, and it never goes above 195F (90 C)
Regards,
Sabbi
Wouldnt 2 watts be a little undersized?The videos I have seen for the 9AT cars show it being removed. It would be RIGHT in the way.
How are they holding up? I wanted to go your route and put a resistor on the harness side and just leave the original solenoid inserted but just unplugged.No smoke yet.
The wires are teeny tiny. They wouldn't carry much mor without getting really soft while current was flowing.
Since I had my engine dropped for upgraded Turbos and Twin disc Clutch I unplugged this solenoid and now have 28psi at idle . A sigh of relief. And when WOT 57psi! Bearings are happy being lubricated now when at idle yess. Before the unplugging it was 17psi. Not good.How are they holding up? I wanted to go your route and put a resistor on the harness side and just leave the original solenoid inserted but just unplugged.
Same here with the oil pressure readings after delete.Since I had my engine dropped for upgraded Turbos and Twin disc Clutch I unplugged this solenoid and now have 28psi at idle . A sigh of relief. And when WOT 57psi! Bearings are happy being lubricated now when at idle yess. Before the unplugging it was 17psi. Not good.
