Oil Solenoid, and P06DA. Anyone have a pic?
Do you have to remove all that crap (AT oil cooler?) just to unplug the connector?
The videos I have seen for the 9AT cars show it being removed. It would be RIGHT in the way.
Even on my 6MT, I had to contort my hand to get the tab flipped up.
I plugged in the 25 ohm, 2 watt resistor today. Taped over it, and zip tied it to the nearby wire. Cleared the code.
No codes or smoke on the way home. And, I didn't need to use a coin!
lol!…a fix without a coin?!? Maybe you didn’t NEED to use a coin, but SURELY you could have found a way to work a nickel or two in there somewhere! :LOL:
Apart from the mod/fix completely lacking the use of loose change, Great Info!
sarbjeetsbains
Sabbi
Nissan Z 2024
Hi Everyone,
Newbie to the VR30 - I have read about the solenoid failing and causing burnout (engine burnout) on the old Infinities.
Could someone please let me know if this is still an issue on the 2024 Z engines? I have a 100k mile warranty on the powertrain on this baby from Nissan. Plus another additional warranty for rest of the stuff until 100k/ 2032.
I am wondering if I should care, or just enjoy flooring? I do suffer from Heat Soak (out of houston) and i definetly hate the 0W-20 recommendation. I would do 0W-40 (previous VW/Audi fan here).
But I would beg the question on that end, does a quart of Lucas fix that problem post Dealership oil change or does the solenoid really need to go go ?
Fulshear, TX
VP
Houston here too! Change your oil regularly to keep the engine clean and you'll have nothing to worry about. RaceBox is an excellent local resource.
For the heatsoak, you absolutely need at least an upgraded aftermarket heat exchanger in this environment.
sarbjeetsbains
Sabbi
Nissan Z 2024
Not sure how prevalent it is on later VR30s, but the reason it fails is contaminates jamming the solenoid. The best thing you can do is change your oil regularly.
Thank you Sir, I am sticking to a 5k to 6k mile interval (as required for the warranty)
I daily this baby, monitor the oil temps, and it never goes above 195F (90 C)
Regards,
Sabbi
Fulshear, TX
VP
Regards,
Sabbi
4-5k is ideal for a turbocharged engine in my opinion, but plenty of debate surrounding the matter.
Oil temps aren't as important as people claim; modern synthetic oil additive packs don't actually even reach their full benefit until 220-230F and will protect well past 250F.
haohmaru
Gregory
New England
24 Z Perf / 13 WRX
Wouldnt 2 watts be a little undersized?
