Ohlins Coilover Setup
Durango 95
West Coast Florida
2026 Nissan Z Performance
Update after initial installation. Had the whole job done at my local Pep Boys. Their Lead Tech takes care of all my mods and does a great job. Feel very lucky to have a tech like this guy. I looked around a lot and visited a lot of shops to find the right guy that I could trust to work on the car. Wish I knew how to do these things myself because the car is in there pretty much every single week. Just getting mods done. This week the car was in there twice. Today I had him raise the car and do some other smaller things including a differential fluid change. Car is at nearly 6K miles and I figured it was time. Since it was in there I also had him adjust the dampers to make them one click more "relaxed" for road use. Bought all parts including SPL suspension parts and the Ohlins from Z1. Car rides really great. Very happy with the outcome. Here's the final print-out on the alignment. I'm posting this so if anyone has any suggestions on how the alignment should look I welcome any suggestions. I'll take a few more photos to show wheel clearance as soon as I get some daylight.
Suzuyabot
Dante
PNW
2024 Nissan Z Nismo
Getting ride smoothed out, I have a stock alignment at the moment but will have it readjusted. Mine is going To be a work in progress, working with settings, height adjustments plus full SPL in rear and SPL FUCAS. The ride is crisp and I have no rub at all at the moment under normal driving or up/down driveway curb. Front wheel air deflectors will scrape a tad on driveway. Will add wheel specs when I have a minute but APEX wheels with 295/305 Conti’s.
Just went with push clips for the adjustment holes in the rear for now. Once set up I won’t need them accessible as much.
Congratulations! The finish looks clean! How is everything so far? Any noise coming from the rear?
Curious about your setups (divorced or true), damping levels f/r and how you feel about the spring rates. I believe @RSS is running 14K true rear where mine is setup with 7K. That seems like a huge difference in stiffness/ride between our Zs. But I believe the off-the-shelf R&T is something like 22K divorced rear, which is around 13K on a true setup (I believe wheel rate is 0.6 or close to it between true and divorced rear).
RSS
Scott
Indy
ā€˜24 Z
Thanks
Just an occasional squeak from the SPL parts, but even then because I am listening for it. I have had it out a few times working solely on settings. The front rides pretty smooth compared to the rears. I am taking 2 clicks at a time out and then driving it for a while to see change. Started 8 from full firm and now at 12 In rear, Fronts are at 10 but they do ride noticeably smoother than the rears. I feel they will have a different setting then the rears when done.
Not sure I could take it as a daily driver (It’s not) because it feels like my set up is leaning further track then street, and I am old. I did have it in the city (Indianapolis) today, it handled city roads pretty good, again the rears felt way stiffer when hitting the patches causing a hop if doing a good pull.
Just different than the other cars that we’ve set up, it will take time to adjust the car and myself.
Suzuyabot
Dante
PNW
2024 Nissan Z Nismo
Thanks
Glad to hear that! It's interesting when I see we both got the same setting on the damper when we are trying to adjust by ourselves. I got 12 on both front/rear (2 clicks more to prepare for rain season), and it runs well so far. And yea the front just feels sooo smooth. Don't mean anything but since hearing from you that you also got some minor squeak sound then I'm eased by the fact that it's normal now. I'm still a bit younger now so I'm still driving this car as a daily, hope I don't regret it a few years later lol.
  • Like
Reactions: RSS
Suzuyabot
Dante
PNW
2024 Nissan Z Nismo
I have 12clicks from full firm on front/rear just for rain season here in oregon. And I'm on true rear, 13K. They claimed that they have different valving for Nismo and performance, so that could be a reason. But still doesn't explain why u got half of my spring rate while you have nismo and are in divorced setting(I remember you changed it back to divorced correct?).
RSS
Scott
Indy
ā€˜24 Z
LOL I was very hard on my body from birth to well I guess the present.
DId you throw almost $10K in parts at your car to run the absurd factory alignment . . . ?
RSS
Scott
Indy
ā€˜24 Z
lol, mine is baseline factory also. I wanted it that way while I tried to dial everything in, then it will get re-aligned to what I want out of it. To each their own.
RSS
Scott
Indy
ā€˜24 Z
Oh I was trying to get info on the Spring and valving ratios being used on these for my son to dig into set ups and also how changing the knob setting affects the compression and rebound ratios. Apparently the knob only affects rebound, very little compression on adjustment. I might try and get different spring sets this winter to play with next year, pretty much done since for now I don’t want to add HP.
Has anybody counted the number of clicks available on the adjuster knob? Seems I had read it was around 24. Mine have 32, when I went back to look I could no longer find that information so just curious.
Imperial
Southern California
Some have clicks beyond the effective working range.
Suzuyabot
Dante
PNW
2024 Nissan Z Nismo
Indeed, even with the revalve, usually after over 20 clicks, the further adjustment will not be linear.
