Need help choosing wheel specs!
RZ34 Maddox
Maddox
north myrtle beach
2024 Nissan Z Nismo
I have a 2024 Nissan Z Nismo. I want to buy a set of Rays Clubsport wheels but I don’t know what offset to go with. I know I want 19x9.5 up front and 10.5 in the rear, but I’m not sure of a good offset, help please!
Best is to contact Z1 for your needs, but if you want to avoid spacers with those stock size widths, I would go with the lower i.e. less positive offsets, +25 front and +12 rear. Clearance should still be OK, no fender rolling, but again consult with them before ordering.
Bumflik
Issac
illadel
Bus Operator
+15 front max and rear +10 max
Hernandooo
Hernan
Straya
2024 Nissan Z, Trek Bicycle
May I ask, why the downgrade? Your Nismo OEMs are pretty good, if not better then the ones you're eyeing on
Edit, nvm I see what you're doing
I'd suggest 19x10.5+22 Front 19x10.5+12 Rear. This will give you the ability to rotate tires given you get all four tires in the same spec.
el mágico
I like the wheels. I like the staggered sizing as well. I did the same with mine.
Here is a screen shot of what I ordered. FWIW.
Nis Mo Z
Moses
Loganville, Georgia
service tech
From a fellow Nismo owner go with the lower offset if you eventually plan to lower. My Apex wheels are 19x9.5 +18 and 19x10.5 +15 but then I later added 5mm spacers so my modified offsets are +13 front and +10 rear
Bumflik
Issac
illadel
Bus Operator
I like! I am waiting on
I love your fitment . Im waiting for my aftermarket wheels and tires to be delivered. I went with Front 19X9.5 265/35 +22 and Rear 19X11.0 305/30 +15 with 5mm spacers for each wheel for modified offsets +17 and +10.
vincenza
Ibrahim
DOHA,QATAR
2024 RZ34
Just bought a set of these wheels 9.5 +25 front and 10.5 +12 rear , I don't have pictures of them installed unfortunately, they fit great , almost perfect , but if you would like a more aggressive flush fitment you can install a set of 5mm spacers on the front wheels and go with the +12 wheels on the rear if you will lower the car.
if you would like flush fitment on the stock height use 5mm spacers on the front wheels and go with the +22 offset for the rear wheels
traska_rz34
Liam
Cocoa Beach, FL
That’s interesting. When I was looking at the Nismo LM-RS1 rims, Z1 said that doing +12 on both the fronts and the rears would give a flush look identical to the stock rims with their spacers. Is that not correct?
I’m also trying to get new rims to keep the fitment but without the spacers.
vincenza
Ibrahim
DOHA,QATAR
2024 RZ34
the stock front wheels which are 9.5 +40 offset , BUT with a 20 MM spacer installed , the front wheels are technically 9.5 +20MM offset , you can see in the photos I provided on the (stock height) my car had an aggressive flush fitment on the front and that is with a +20MM offset front wheel , I believe +12 on the front wheels would make the wheel poke out a little if you don't lower the car and increase camber
White House, TN
2025 Nissan Z Sport
With those options I'd get the least offset on both the front and the rear; +25 front & +12 on the rear. I got the Z1 Motorsports 19 inch wheels they sold as a set for the Z and those offsets are Front +15 & +5 on the rear.
el mágico
Nice wrap! Is it matte gray? (name color non-specific).
