My patience just ran out.
Blackbeard
Anthony
mia
22 Supra
Mechanic
Please explain to me how one wheel peel is more dangerous than 2 wheel peel.
I'm ready to be enlightened by your expert take on the matter....
im not sure if this is a serious question but without a lsd when u apply power the power only goes to one wheel which in turn could make u slide more to right or left depending , in a lsd power is applied equally to both rear wheels.. never mind i took to long to write this lol
Kbl911
K
2023 Nissan Z Proto Spec
Wealth Management
However, never is LSD "safer". If both back wheels break loose, unexpectedly, on slippery surface with a crown, your headed for the curb. If it happens mid-turn/corner, you're swapping ends.
I had a HLSD Trutrac installed on my truck. It's freaking dangerous in the wet, and I won't let my wife or son drive it on a slippery day. But it's awesome off-road and doesn't do one-wheel-peel anymore.
It's a bit more nuanced than you're making it, though. Another part of the equation is the stability and traction management systems built into the vehicles. Generally speaking, these will augment the behavior of the LSD and provide an additional safety net since ESC systems can manipulate braking action to further try to equalize the power between wheels and prevent a spin-out.
Anecdotally, I have never had a vehicle (RWD, specifically) with LSD squirm unpredictably in wet conditions at freeway speeds under steady throttle (this is with an ESC system engaged), yet I have absolutely had an open diff behave that way. Very unnerving, obviously. Thus, I would personally conclude that the open diff is less safe in inclement weather, excepting perhaps snow/ice, which is not a consideration for me.
  • Like
Reactions: Leo
My truck doesn't have any traction or stability control. The difference between LSD and open is represented without being clouded with traction aids.
If the truck had modern traction aids, I would bet it'd be perfectly safe with either diff type. Then we'd just be discussing the obvious benefits of LSD.
My point is it's ridiculous to say open diff is dangerous or less safe than LSD. That's not true, and an open diff vehicle getting squirrelly at highway speeds sounds like something other than a diff issue
Sorry, but you should research more about how diffs apply power and how traction loss occurs with different types of differentials.
I'm starting to feel like I'm talking to a wall here.
Again, I am only talking about the 2 previous assertions that open diff is somehow unsafe. When people don't understand, they seem to double and triple down on their assumptions.
Kbl911
K
Wealth Management
Oh, wow, that must be an older vehicle. My point there was to say that an LSD in wet conditions versus an open differential in those same conditions still has the advantages inherent in the LSD and that there are other systems that would potentially stop either one from spinning out or flying into a curb (in any US -market vehicle produced after 2012, I believe), so that's a little dramatic. I can see that wasn't entirely clear, now that I look at it.
Open diffs are not inherently unsafe. That's obviously not true; they're far too common for that to be even remotely the case. But if we add in significant power and a classic FL downpour, the LSD will have advantages over an open setup, just by design.
You know, I thought the squirmy behavior was strange, too! But no issues with the vehicle were identified upon inspection. Not even the tires or alignment. It was not a terribly uncommon experience but it was a frightening one. Just spinning the one tire in the rain on the freeway - good times! ?
Yup, 2007 Titan VK56DE, lots of torque and very sketchy in the rain. Also the throttle on these trucks is a bit too aggressive exaggerating the issue.
Newer vehicles are much better.
Houston.RZ34
Texas, USA
Q70S 5.6 | Stingray Z51 HTC
COO
With open diff, just let go of the gas.
As for prices, since everything else seems to "outshine" the Z......demand will be low and sales will be slow.
I can't wait to see how they end up after the bubble pops. I was able to get away with a 2010 40th Anniversary that had 27k miles on the clock for a whopping $21,000 back in 2014.
350s and 370s deprecated, hard.
Blackbeard
Anthony
mia
22 Supra
Mechanic
Ok guys pack it up he has spoken, master tech doesnt know shit , end of thread
Kbl911
K
Wealth Management
Totally - the 350s were hit particularly harshly by that depreciation. 370s have maintained their value better (particularly post-facelift models with average-to-low milage) but that may be soon to taper off.
I am super interested to see how the initial sales for the new vehicle go and if the combination of lukewarm test results/reviews and the hilariously sloppy rollout have an impact on the prices of the early Zs in a few years. Nissan may find themselves struggling to move units after the initial flurry, and even that might be a shorter window than normal.
Houston.RZ34
Texas, USA
COO
I somewhat disagree, the 09-12s fell really hard IMO. My 40th fell ~50% in just 3 years.
But, I do agree those DRLs must be made of platinum and Diamond because the 13+ seemed to hold value for a good little bit and never really dipped too under 20k and anything 15+ held value because they hardly made any 370s at that point.
Funny part is, there were 0 major changes from 2009-2020 - it's the same damned car.
Yeah, yeah......12 had the oil cooler (lol) and 13 brought the "refresh" and added Bose to the Nismo as an option, 15+ had the Nismo v2 and they added an Auto option. I think in 2018 they made bluetooth standard, took away the fender turn signals and included a trunk popper button.
Kbl911
K
Wealth Management
Right, there's the caveat of the post-facelift models bringing up the averages, and that's partially just because they are newer vehicles. It's coming, though.
MHockey17
Pennsylvania, USA
‘18+ also added Dunlops derived from the GTR and an Exedy clutch which is (allegedly) a vast improvement over the original setup; Not major changes by any means, but would sway me to the late model 370Zs if I was shopping for one.
As a side note: the fact it took Nissan till 2018 to add a way to pop the hatch from inside is kind of ridiculous. Alternatively they should’ve just sold Zs with the 4-button fob that includes a trunk button, since it’s already an electronic release.
And weren't the Nismo 370Z Recaros not completely Recaros, just the seating surfaces, not like what's in the Juke Nismo which are real Recaros with great bolsters?
Wow, I didn't realize Nissan futzed around with the Z so much! The Infiniti coupe had BT and interior trunk pop button from day 1. I didn't think those items were special....
