Is it safe to blend 93 and e85?
Tranzor Z
I've heard of people adding a gallon or two of e85 before filling up with 91 or 93, whatever is available at that particular area. Not in a Z, but other vehicles. I'm new here.
It blows my mind that not all new cars can run E. But it's whatever.
What are y'all doing?
I run only 93 but I'm curious if anyone has tried this blend yet or what the safe ratio would be.
-Stevie Ray
Yes, I did it all the time in my C7 & C8 Corvettes. The LT-V8s were happiest at 95-octane so I typically added 3-4 gals of E85 per tank of 93.
I'll splash blend our Jeeps too as the Pentastar V6 likes 89-octane (87 + 2-3 gals of E85).
Officially, Nissan approved the Z up to 15% ethanol but you're perfectly fine taking it up to 30%.
I'd personally stick to 2-3 gals of E85 per tank of premium due to the Z's smaller tank size. 3 gals will net you 23% & 95-octane.
Luckily there is a station near my office with 88E15, E85, 87E10, 89E10, 91E0, & 93E10 all available at the pump!
Let me know if you want a blend calculator I made and I'll happily email it over.
Tranzor Z
Tranzor Z
Absol
You have a Z and are actually blending? Is that correct? No issues?
Tranzor Z
Tranzor Z
Absolutely email it to me please
% ethanol in E85 pump can vary quite a bit. are you guys measuring the %e in the E85 before calculating and mixing?
I assume 80% to err on the high side. 70-75% is typical, but it can be as low as 50% or as high as 83%.
If it's useful for people they're welcome to it; see attached. The other tabs are old, but I updated the Z tab this morning.
abdullah
rz34
99628818a
z400
[اقتباس="KrackaC8، المنشور: 147144، العضو: 4761"]
نعم، كنت أفعل ذلك دائمًا في سيارتي كورفيت C7 وC8. كانت محركات LT-V8 تعمل بكفاءة عالية عند أوكتان 95، لذا كنت عادةً أضيف 3-4 جالونات من E85 لكل خزان بنزين 93.
سأقوم بخلط سيارات الجيب الخاصة بنا أيضًا لأن محرك Pentastar V6 يحب 89 أوكتان (87 + 2-3 جالون من E85).
رسميًا، وافقت شركة نيسان على إنتاج سيارة Z بما يصل إلى 15% من الإيثانول، ولكن لا مانع من زيادة هذه النسبة إلى 30%.
أنا شخصياً سألتزم بـ 2-3 جالون من E85 لكل خزان من الوقود الممتاز بسبب حجم خزان Z الأصغر. 3 جالون ستمنحك 23٪ و 95 أوكتان.
لحسن الحظ يوجد محطة بالقرب من مكتبي بها 88E15، E85، 87E10، 89E10، 91E0، و93E10 كلها متوفرة في المضخة!
أخبرني إذا كنت تريد حاسبة مزيج قمت بتصميمها وسأرسلها لك عبر البريد الإلكتروني بكل سرور.
[/يقتبس]
وضعتُ علبتيْ بوستان سعة لترين تقريبًا في نصف خزان وقود سيارتي. الآن، كلما ضغطتُ على دواسة الوقود بالكامل، يتصاعد منه دخانٌ عكسي. هل سيؤثر هذا على السيارة؟
myphsto
Joel
WI, USA
2023 Nissan Z Performance AMS Alpha 5
If you live in a reformulated area where there is E already in your 91 or 93 I'd be careful unless you upgrade to a flex fuel kit. I'm running the AMS flex fuel kit with a tune, and I can run 91 all the way to E85 and not worry about detonation due to falling off stock map timing.
I took samples and used an E85 tester to check my local fuel stations.
SAMS 93 pump measured ~8% and Spinx’s E85 (105 octane) measured ~80%.
per the calculator below using a target of 20%, I mixed in 2gal of Spinx E85 and 6gal of shell nitro 93 pump with the tank 1/2 full. So my tank ended up at ~17-19%.
see links for the on-line calculator and the tester i used.
Ethanol Fuel Mixture Calculator
https://www.getmtuned.com/ethanol-fuel-mixture-calculator
REV X E85 Super Tester
https://a.co/d/7b3XDUR
