Has anyone replaced the seats?
bgordon27
Massachusetts
I have been okay with the seats since I got a memory foam mat to sit on. Not great, but cushions the metal and plastic on the base well.
JonnyG
Jonathan
Do the OEM seats (in Performance if differnt) have lumbar support - that is big for me. Disappointing to hear many don't like them.
Yes, in the Performance, manually adjustable.
OCPanther
Maurice
Irvine, CA
2024 Nissan Z (sport)
Teacher
Pretty sure Nismo recaros from a 370Z will plug in. The wire harness on both cars should be the same offering connections for power to move the seat, heat, airbag sensor and seat belt.
The Nismo recaros will only need connections for airbag sensor and seat belt the rest will be unused. Worst case scenario if the seats dont have the same connector for the airbag, you can try this very cheap but effective work around.
That said, I just swapped out my factory seats this weekend...this is the result and im pretty stoked about it. These seats, brackets and rails are also direct fitment for the 370z FYI
That looks absolutely amazing brother!
northshorez
Massachusetts/Florida
2023 Nissan Z Performance,2024 Hyundai Palisade
I might try that myself, have an arthritic hip and usually after driving more than 45 minutes it starts throbbing, looks like the plastic base might be causing it?
Im a big guy (6"2" 225)and otherwise have plenty of legroom, headroom,sholder room
The Recaro's in the Nismo are extremely comfortable. Should be a easy swap. FYI they're not power seats, but still have excellent manual adjustments.
So what is the difference, if any, of these Nismo Recaros vs the 370Z V2 Recaros, mount-wise and electrical connections? My guess the mountings are identical but not sure of the wiring adaptability.
kappa_md
John Paul
Manila, Philippines
Surgeon
I replaced the stock seats from my Nissan Z Performance MT with Recaro SR-S. Feels very much OEM but way better driving position. Lumbar support is good with ample lateral bolsters for spirited driving. This new release Recaro SR-S were specifically designed for modern-day sports cars with low driving position such as the Nissan Z RZ34
D2M
Nismo Z, Veloster N, Ram 2500
Very nice... What did you do about the airbag connection? Resistor?
kappa_md
John Paul
Manila, Philippines
Surgeon
No need for additional resistor/relay. The Recaro baseframe already includes side airbag wire to cancel the stock one. You also need to attach the seat occupant sensor to the Recaro to avoid airbag warning ?
ChrisD
UK
www.youtube.com
2023 Z Proto, 370Z, BMW M2
Quick question as you mentioned these seats are good for cars like this with a low driving position - do you mean that these maintain the low position or that they let you adjust it? My main issue with the stock seats in my proto Z seems to be that the seats are just too low and don't have any real height adjustment
kappa_md
John Paul
Manila, Philippines
Surgeon
Unfortunately, these don’t have height adjustment either. But it is a tad higher than stock, yet still maintains the low driving position.
linebacker14R
Steven
Venutra,Ca
2024 Nissan Z Performence
Test Car Driver
My issue is feel the seats are sitting too high up...I'm 5'10" and I'd like to sit a bit lower...
bgordon27
Massachusetts
I had an auto body shop take off the plastic trim. It's much better without the hard plastic under the cushion.
I raised the front and back of the seat bottom and it helped a lot. I have never had to do that FWIW.
