Hands Up all the Aussies
Supremekai
I hid the wires with the airbag. The ground wire is attached to somewhere near the hood handle.
I got the a piller off and routed the wires under it.
I don't see the metal part where you have your ground. I'm trying to take the fuse box trim off but don't know how to remove the plastic fastener above the dead pedal... So I can find/use a ground point behind the trim
Edit: finally installed. I used a plier to stick it between 2 of the 4 holes and twist counter clockwise and it came out.
peter
Peter
2023 Z, Qashqai
Metallurgist
Fitted front and rear sway bars with new front and rear endlinks from Whiteline yesterday, haven't had a chance to drive yet to see the difference.
Got them through Fulcrum Suspension on a black Friday click and fit offer
MattJ2020
WA
2024 Z
Photographer
Pick mine up this Friday
Same color as mine! Love it… but I’ve got the black interior.
On another note, does anyone know how I could remove (in this example) the red interior parts that are red along the dashboard and gearbox area? Want them reupholstered in alcantara ?
Mud
Brisbane
I call these the knee pads, but I think they're referred to as "Console Finishers"
Steps 19 - 30 in this should get them off.
https://www.nissanzclub.com/forum/attachments/mc-10226134-0001-pdf.16297/
I don't think 19 - 24 are required, I don't think you need to remove the console / cup holder assembly. Pretty sure just removing the gear shift surround will be enough to give you access to the screws on the console finishers
Mud
Brisbane
I bought the Ottocast A2Air and Andriod Auto works great wirelessly, also paired it up with a wireless phone charger that fits in perfectly next to the USB outlets.
Hey @peter
Does this fit in the slot above the USBs? Got a pic of your set up?
jc604
@jc_rz34
canada
  • Sad
Reactions: Mud
theboosh
XV
Bummer! So far so good for mine but it definitely looks pretty generic/not expecting it to last forever.
peter
Peter
2023 Z, Qashqai
Metallurgist
I'm going to get a longer cable and tuck the ottocast behind the panel.
This one works great no drop outs connect straight away
Hammo25
Jamie
Perth
Audi A5
i boughtone during black friday sales and ultimately returned it. It was laggy when switching music and it couldnt last 20mins in the car without disconnecting. It seems these issues are well known for these wireless things :(
I bought the Ottocast U2-X Pro and since setting it up right it’s worked almost perfectly. The good thing about this unit is the support for multiple phones and then turning auto connect off. When you start the car it’s just a case of selecting the previously connected phone you want to connect to - even if it’s only the one phone option. I have put the same unit in an Audi and a Hyundai and it works great in all of them. The Hyundai has wireless but the connection was super flakey. Using the ottocast wired in by USB and then wireless from there works near perfectly. Unit is small like the others pictured here.
  • Like
Reactions: Mud
