JChandler82
Josh
WV
Director of Endpoint & Infrastructure Support
Hello Z lovers!
I wanted to share my experience and the path I took installing a subwoofer in my 2024 Z. There are a few other threads out there with pieces of this information—which were very helpful—but I couldn’t find a single place that walks you through the entire process from no sub to a fully installed system (annoying your neighbors included 😂).
Disclaimer: I am NOT an audio expert by any means, and I don’t claim to know even 1% of what a professional installer does. I’m an IT guy who enjoys big bass and DIY’d my way to it. I’m very happy with the results and just want to share my experience so others can tackle this themselves if they choose.
Parts List:
As my parts arrived, I installed them while continuing to research along the way.
Line Output Converter (LOC)
I started with the LOC. First, I tapped into the factory Bose speaker input (this signal is modified by the factory amp). If you want a cleaner, unmodified signal, you can tap into the speaker wires directly from the head unit before they reach the Bose amp. That said, I’m happy with my current sound and don’t plan to change it.
I used Posi-Tap connectors to tap into the wires. Looking at the plug connecting to the factory installed Bose spare tire sub, the top two wires are positive, and the bottom two are negative. I initially tapped all four wires before realizing that only one set is needed for my LOC.
Note: These are NOT T-tap connectors. While T-taps may work for some, they’re not recommended due to potential connectivity issues.
After making the connections, I ran the extended speaker wires to the LOC.
If you don’t want to tap the connections, you can buy a wiring harness adapter from OWC Upgrades: Z (2023-2025): Audio Interface Harness Adapters, PLATINUM SERIES | OWC Upgrades
For power, I used a 12V cigarette lighter fused adapter. There are several ways to power your LOC:
  • Use signal sensing (some LOCs can turn on automatically when audio is detected.) Allowing you to tap into the amplifier’s power and ground.
  • Use an “Add-a-Circuit” fuse tap (research required) https://amzn.to/4suIfdi
I chose the cigarette lighter option so I can easily disable the system. If the car is being serviced or valet parked, I can simply unplug it and prevent anyone from accidentally cranking the system. Love it or hate it, this was my own idea, and I thought it was cool.
Power Wire & Firewall Entry
Next, I ran the 4-gauge power wire and ground.
I found what I consider the perfect firewall entry point in another forum thread. It’s located just behind the battery and routes into the passenger-side footwell above the carpet. It’s difficult to photograph, but it’s ideal. So much so that the grommet from my wiring kit fit perfectly in the hole after removing the factory rubber plug. Once your power cable is in the cabin, pop the kick plate and side panel off and route your wire under it. There is one threaded plastic screw you’ll need to remove, and the rest of the panels are held on by clips… just pull up and away from the floor.
Grounding & Amplifier Placement
I positioned my amplifier on the shelf behind the passenger seat. Removing the fold-out drawer provided easy access to the trunk area under the carpet, where there are multiple grounding points.
I chose a bolt securing the factory Bose amplifier bracket to the body, as a voltmeter confirmed a solid 0-ohm ground.
Disabling ANC (Active Noise Canceling)
Before finalizing the ground, I removed the amp to disable ANC.
From my research, Performance and NISMO trims with the Bose system have ANC enabled. One way to disable it is by unplugging the microphones used in the system. This breaks the circuit and turns ANC off.
Why this matters:
ANC will interpret your subwoofer’s low frequencies as “noise” and attempt to cancel them out by sending opposing sound waves through the speakers. This can cause:
  • Buzzing
  • Pulsing bass
  • Reduced overall bass output
Unbolt the amplifier bracket from the body. Wiggle it out enough that you can reach the plug closest to the driver’s side. This is the plug that contains the wires for the ANC microphones. Remove the plug from the amplifier to access the wires for removal.
Wires 5,6,7 ( blue, yellow and violet) are the positive leads of the microphones. Remove them from the plug and tape them off with electrical tape. This process manually disables the microphones, disabling ANC.
The pin removal is a delicate process. Be patient. Here is a video that helped me understand the plug styles and functionality to learn how to remove the pins properly:
Automotive Connectors Pin Removal Guide | Learn to Remove any Terminal From any Connector
Other ANC Disable Options
You can also have a dealership disable ANC, but you may run into issues:
  1. They may not know what you’re referring to
  2. They may claim it voids your warranty (it does NOT—ANC is not a safety feature)
  3. They may charge you (some have reported $250+)
If you go this route, I strongly recommend also disabling ASE (Active Sound Enhancement). ASE plays artificial engine noise through the speakers when in Sport mode—and you definitely don’t want that coming through your new subwoofer. It sounds terrible.
Dealerships can disable both ANC and ASE using their Consult III system. Take these screenshots with you and it may help them understand. These screenshots show where to go in the program to toggle off ANC and ASE/ASC.
Another option is to disable it yourself using an OBD connector and compatible software (see supporting forum threads for details).
Final Notes
Amplifier placement and cable routing are completely up to you—get creative and enjoy the process. I haven’t fully cleaned up my wiring yet because I wanted to test everything for a few weeks first.
That’s It!
From here, you’ll need to tune your system:
  • Gain
  • Low-pass filter
  • Subsonic filter
  • Etc.
If you’re willing to take the time to learn and do it yourself, I highly recommend it. I had a lot of fun with this project, and having the knowledge to troubleshoot or upgrade in the future is a huge bonus.
I used AI to help figure out the proper gain settings and ways to test for clipping. Amazon has a great cheap O-scope you can pick up: https://amzn.to/427G57D
Hope this helps!
Here are some resulting shenanigans:
Supporting threads:
Comparison of ANC/ASE on and off | 2023+ Nissan Z Forum, Community, Owners, News, Discussions (RZ34)
Since my dealer charged me 230$ to disable the ASE, I will do it myself | 2023+ Nissan Z Forum, Community, Owners, News, Discussions (RZ34)
Factory audio system questions. | 2023+ Nissan Z Forum, Community, Owners, News, Discussions (RZ34)
sarge
steve
Western Slope Colorado
2024 Z Sport
Retired Army
WOW, great post. Thank you for doing that. It’s so simple to unplug the mic power, fantastic tip!!
JChandler82
JChandler82
Josh
WV
My pleasure man! Hope it helps someone someday. 👍
Cabeza187
Las Vegas, NV
Good stuff. Im in the process of this right now. Thanks for posting. Been waiting 6 weeks for the OWC harness, still not here yet.
JChandler82
JChandler82
Josh
WV
Thank you! I saw in the other threads people were waiting a while. What sub / amp you doing?
JChandler82
JChandler82
Josh
WV
DD Audio SL612-Its a slimline 12inch
DDAudio D1100
I used a similar box design as Mr. Mac
awesome. that will look and sound great!
JChandler82
JChandler82
Josh
WV
Got some video of the action! 🔊🔊🔊😈😈
sarge
steve
2024 Z Sport
Retired Army
A sound wave decays/loses amplitude from the moment it leaves the speaker. Reflecting off a surface such as glass will not increase it.
JChandler82
JChandler82
Josh
WV
Facing the rear can definitely increase dB's for low bass frequencies. It has something to do with the length of the sound waves in those tones. I think they call it cabin gain. If you can get the right position of the speaker to the rear surface it can reflect forward and combine with the next wave coming off the sub. It sounds counter intuitive, but it can work for sure.
I've faced mine all directions and I think I like the sound the best blasting straight into the back of my head 😂
JChandler82
JChandler82
Josh
WV
I will say, this car is solid. I'm getting basically no trunk rattle from the outside. And the only in cabin rattle I'm getting is from the plastic cover on the stuff behind the rearview mirror, and I think it'll be an easy fix.
chander0
I had put this project on pause as I saved some money for a professional install but your thread is making me want to just go for it. I’m in the same boat - not an audio expert but I’ve installed systems in all my old cars myself. My last car was an Infiniti and I only needed a sub. I grabbed the signal going into the oem sub from the oem amp to my LC2i.
This is my first car with ANC / ASC though..
I keep reading how terrible the sound on an aftermarket sub is if you don’t disable those. I’ve read all the threads and know that a clean signal can be obtained from the headunit but I don’t want to rip apart my new car so soon. It’s my first car with warranty lol. Also not sure if I want to disable them. Maybe I will down the line.
Is there a reason you got your signal for the LC2i from the oem subwoofer input vs the input to the oem amp from the headunit? Wouldn’t the signal into the amp be clean vs the anc/ase that’s added after the amp?
Kind of like grabbing it from the headunit but just using the wire that’s already run to the back.
JChandler82
JChandler82
Josh
WV
Good thoughts! You could for sure grab the audio signal from the wires right before the amp. They are spread out on the other two plugs right beside the one with the microphone wires I removed to disable ANC. I bet that would get around the fake engine sound (ASE,) maybe. The ANC, noise cancelling, I think would still be an issue though because it uses the door speakers to try to cancel out your subwoofer.
My plan to tap into the wires after the amp came from some YouTube videos I found on other vehicles with the Bose gear, where they installed using that method. Then I saw that aftermarket harness I linked and just kinda assumed it would be fine.
