Really nice!
Not sure how involved adding the charger will be to a '23-'26, but that may be a pretty popular mod.
im not sure how that would be easily hardwired? would need a whole new lower console ?
If it's built in (like really built in) it definitely would be a pain. If it's not on every trim maybe it's sort of an insert thing, which wouldn't be as bad. Regardless, it would need to be wired, and I prefer not to dismantle the dash to avoid introducing squeaks and rattles.
You have a good point as it isn't on the sport so even though it's an insert that area on mine is solid and just has a rubber pad over it
Hadn't looked under the pad. If it's one solid floor(?) under there then wiring AND installation of the '27+ OEM charger would probably be a pain.
Am I the only one that likes the existing front bumper better?
I’m with you. Back in the day all of the body kits (or most) would always move to a large squared up “wide mouth” front grill, usually with a giant air to air intercooler front and center. Our standard setup reminds me of that look so, I like it. I just think most people want what they don’t have. If something is closed up, they want it open and if it’s opened up, they want it closed. If it’s big, they want it smaller and if it’s small they want it bigger. Or in some cases even if it’s big, they want it bigger. 🤣. I like the front end of my 24 performance better than the Nismo. Not on the 370 though. I like the look of the Nismo 370 front end.
Maybe that rectangle piece pulls out?
also to look 100% OEM you need to replace the panel around the shifter as there is a charging indictor light there
VtVince
Vince
Vermont
'24 Nissan Z Performance, '23 Honda Ridgeline, '24 Mini Countryman S All4
I heard they fixed the fuel starvation issue on the '27s. I always keep mine topped up and I'm not tracking it, so I don't have personal experience, but it seems like it might warrant a recall if others have.
thehunter699
Mitch
Canberra, Australia
'24 Z Nismo
Anyone notice they removed the Nissan badge on the front for a Z badge?
Looks lazy, now you've got a bit gap around the Z badge on the bonnet.
