David Montgomery
David
New Hampshire
2024 RZ34 Performance 6MT, 1981 S130 Turbo 5MT
Really nice!
Not sure how involved adding the charger will be to a '23-'26, but that may be a pretty popular mod.
And the front bumper with the Z emblem
AlanZ
Alan
Civil Servant
Imperial
Southern California
2023 Pathfinder Rock Creek, 2024 Z Nismo
I’m assuming that if we get a manual Nismo then there should be a Nismo button! It only makes sense…
The SynchroRev button was added to one of the blank buttons where the heated seat switches would be on the Performance models. That about all I can tell that's different button wise.
up4speed
Long Island, NY
Still no info on what Nissan actually did/changed.
I would love to also hear what they did to fix the starvation issue. If it's an easy fix, I would like to do it. I looked into the additional pump and didn't like it for a few reasons. If I remember correctly, one of the reasons were that the fuel gauge becomes very inaccurate. I don't remember the other reasons off of the top of my head. So I decided it was better/easier to just keep it over 1/2 full at the track. The only real disadvantage of this method, is dragging around all the extra weight on an already "pleasantly plump" car
Zplz
Dave
2025 Z Sport AT, Lexus ES350
Indeed. I believe a full tank of 93 octane is over 110 pounds in the Z. That's like driving around with a hot, fit lady next to you. She'd better be worth the weight. ;)
Gas is right at 6 lbs per gallon, and the tank is 16.4 gallons. That's about 100 lbs full to the brim. Assuming when you're running on empty you've probably still got a 1/2 to 1 gallon in there
(not certain), so the delta between running on fumes and a full tank is about 95 lbs.
Fixing starvation and allowing you to run 1/4 tank vs 1/2 or 3/4 tank saves around 25 and 50 lbs respectively.
I can’t wait for the red Nismo manual sport mode button to be available!
The 2027 manual NISMO gets D-mode from the automatics because it has to have sport + which changes the actual engine timing itself. The NISMO without sport + is does not take full advantage of the different engine tune that allows for the extra power. What they did was keep the syncho rev match ( s mode but move it to the vacant heated seat button.
Zplz
Dave
Yep. Why carry extra weight when you don’t have to.
This makes me sad. I wonder if there is a way to use the Nismo d-mode switch and rewire it to work for us non Nismo guys that want our switch to be red.
No because it's tied to the tune they switch has nothing to activate.
