WHO.AM.EYE's dream journal
I was going to have a good day with a buddy installing extended studs today. Rears said, not today ?
The dust shield being in the way didnt give enough wiggle room for 60mm studs to clear. Time to shave off 5mm for clearance
Fronts were the smoothest. Stock lugnuts will fit with 15mm spacers without bottoming out
Finally got everything back together. The 60mm extended studs wouldnt fit the rear without removing the hub. I ended up ordering 50mm extended studs. They fit without taking apart the Ebrake or removing the hub
I havent done anything to the Z since my last posting. Here is a story that I am not proud of.
Not my brightest moment owning the Z this week. My temper got the best of me on Wednesday. I overloaded my clutch for a couple seconds in 5th, then at 7k rpms, shifted to 6th and it had no power to the wheels. And the clutch was soft when I dropped into 4th, hoping it was a minor issue. Lucky, the clutch engaged and the drivetrain was working again and all the gears felt good. Came to a stop, and if you know what a burnt clutch smells like. I'll just say, it was worse than normal. I went under the car and saw no signs of fluid leaking.
The smell took 3 days to go away. Today, the smell is completely gone. I could probably say that my clutch, and possible flywheel is glazed like a donut shop. A few thousand miles was taking away from the clutch.
What would you recommend for an aftermarket clutch? Should I flush the fluid now and put in clean fluid and try to keep the clutch going until it goes out?
My Z is not a manual but I've had plenty of manual sports cars in the past. These cars can take a beating man, no need to be so hard on yourself.
I would just keep driving it like you stole it.
The clutch will let you know when you need to switch it out. A one time event like that is not going to kill it. That loss of power was probably the car saving itself from damage, it was probably a good thing in the end.
That's my take.
Sounds like you overheated your clutch fluid, hence the soft pedal. Flush & bleed with a quality high-temp DOT4 and you'll be good to go. I personally have ATE TYP 200 in mine, but Pentosin Super DOT4 is also good stuff.
Thanks @5amp5on I'll keep an eye on the clutch and see how she acts in the next 10k miles. Im at 17k now.
@KrackaC8 do you recommend ATE Type200 fluid for brakes on a daily driver? I have that ATE Type200 fluid sitting in my cabinet for the past 6 yrs. Guess its time to crack it open and use it 😅
6 years old it belongs in the dumpster; DO NOT use it.
I do like the ATE for daily drivers as it lasts longer (3 years) than most other high-temp DOT4s. I have it in my brakes & clutch across multiple vehicles.
Never been opened. Shelf life on unopened can is 5 yrs. I'll flip a double headed coin and call tails to use or not use 🤷🏽‍♂️
DO NOT USE IT
You cooked your clutch once, why risk it, and your safety, over a ~$20 can?!
Havent done much to the Z. Just some quarks and revaluating my bolt ons.
When listening to music with bass, i can hear the regulator rattling. Cracking the window and the noise goes away. Took her into the dealer for a diagnostic knowing the warranty will be covered. The results came back that they need the car for half a day, to a full day to dig into it further. Had to reschedule since I am going on a business trip for a week.
Removed the AT muffler/axleback. Went back to the MT muffler/axleback for now. Forgot how quiet the chunky muffler is. Not gonna lie, it did allow me to hear the rattle in the passenger door from my driver seat. With the louder exhaust, I didnt notice it.
I havent figured out what exhaust I want to reach my 450 whp goals. With brands and options for the Z, it becomes overwhelming. Comparing, valvetronic, to less drone, to best for HP gains can get deep into the rabbit hole.
To add in the added cost, depending on the exhaust, HPFP might be added to help reach that goal.
Follow up to a less successful outcome. The service advisor said they wrapped some wires behind both door panels. They could not hear the rattle during the test drive. I told over the phone before picking up the Z, I didnt hear it when driving or when the window was cracked. Only when the music was turned up with bass. They said we did that and did not hear the rattle.
Great, thinking it was fixed with a little bit of doubt while heading to the dealership. Behold, the rattle was still there in both doors. When I jumped in and blasted some R&B music while the service advisor was in the driver side and me in the passenger side. Advisor said we will order the driver regulator and see if that fixes it. Went to open the passenger door and the door handle and lock wasnt hooked up 😡 I didnt have them fix it because I will drop off the car when they get the part in.
My fault for not having a tech or the service advisor in the vehicle to listen for the rattle prior to them doing the work 🤦‍♂️
Now that I just wrote this, Im going to reach out to the service advisor on Monday to have them order the passenger regulator. If they are going to take apart the door panel for the handle, might as well do the regulator.
Thanks to @Mugzilla, the rear diff showed up in one piece. Now to find time to get it installed with the help of a friend. This pumpkin weighs 100 freaking lbs 😡
I have lifted BMW E46 M3 LSD diffs and they dont weigh this much.
Here is the update from this post on the window regulator warranty claim
https://www.nissanzclub.com/forum/threads/who-am-eyes-dream-journal.4149/page-2#post-186709
I talked to the Service Manager in person and he was understanding about ordering both regulators. Told him I found a few online sources from other Z members on FB and Forums who had confirmed the regulators fixed the issue. I went on that no Nissan site could confirm that was the fix. He said, thats usually the case if there is no NHTSA Recall for it.
After both regulators were replaced, the car has no more rattles from the windows. Cant say for the rest of the interior 👀
I wasnt sure if 12mm spacers all around was the ticket. I kept visually seeing the front a little further in from the rear.
Today, decided to throw on the 15mm on the front. Used a leveler and a tape measure. Front and rear had exactly a 3mm gap from the edge of the fender to the wheel lip.
Now to get 265s and be happy until I can get the Diff installed before the weather gets colder.
