The Z dyno thread
Evolution
Sean
CA
Dont ask
Thread derailer
The AMS post states this tune was on 93.
The 109 tune was a previous run with a non-Proto.
So it makes virtually no extra power on 109 over 93? Kinda hard to believe.
MHockey17
Pennsylvania, USA
The torque curve on this graph looks as if this is about the max the stock setup can push before choking and requiring supporting upgrades.
The Z with the 109 tune also had upgraded LDPs, and I believe it was stated the only reason they tuned on 109 initially was so they could benchmark safely without risk of detonation; don’t remember them claiming that it was required to hit those levels
I imagine they could’ve pushed farther on that grade of fuel
Evolution
Sean
CA
Dont ask
Thread derailer
I agree with your first sentence. You see how fast it peaks power and then just dumps off? Turbos are done. I can't even imagine how much heat they are pumping out. I would call those pulls dyno queen #s. Great to see the engine can do that stock though. More like a full send it pull just to see what it can do, once and only once. I can imagine, more like, would hope, that the OTS tunes are a bit more conservative. Got to keep those IATs in check to be reliable/consistent.
Evolution
Sean
CA
Dont ask
Thread derailer
I was going off post #21 btw. Not the other post that you can barely even tell what the numbers are.
MHockey17
Pennsylvania, USA
Yeh they are reportedly “small” turbos on the VR30 so I can’t imagine their efficiency range is very high.
One of the characteristics of the previous VQ engines in the Z cars that I really enjoy is the smooth linear power curve that climbs all the way to redline. The massively higher torque here would definitely be fun, but I agree that steep fall off up high would be disappointing. Hopefully the Pure Turbo upgrade, or Z1s new turbos can remedy that.
Hard to say how reliable this tune would be longterm considering this is still just their R&D car. Looks promising tho, excited to see some actual customer cars running these.
Zboy
America
Z32
Google translate -
450.06ps 61.46kgm with replacement muffler
495.17ps 71.98kgm with CPU Over 500ps guaranteed if you change to meta-cata
ZMidlife
Louisiana
Industrial Gas
@Racebox with all the VR30s you've tuned is the Z underrated from factory? I assume the traditional drivetrain loss factor is still 12-18%. Should be a 330-350rwhp car at 400hp. Are the dyno #s inflated or the car is underrated?
Racebox
Diamond Sponsor
Racebox
goracebox.com
2023 Nissan Z
Tuning/ parts installation
From what we've seen on *our dyno*, stock Z's and RS Q's make about 350-370whp- sometimes lower depending on fuel quality. Plus, some dynos will read higher than others due to correctional and ambient outside factors. This is why we give a general range and never an exact number.
Here's a great video of our Z back in the day from when we first dynoed it:
