KelvinllMelvin
- Thread starter
- #1
Finally got the mounting nut off from the shock absorbers and installed my eibach springs, the front springs are on right now but I want to know what I did wrong because oh boy installing just the fronts took all day literally.
Took the stock “coilovers” no problem, pb blaster came in clutch. But as I removed the stock spring and on the eibach springs, mounting the strut back on to the car was SUCH a hassle. I couldn’t get the bottom mounting bolt/nut aligned together. Upon careful inspection the hole on the shock absorber where the bolt goes thru and tightened by the nut (I’ll have a pic circled for reference) was a bit angled off. Raising the lower control arm was no use and it was angled horizontally. I tried twisting the shocks hoping a little budge would align it, no use.
I had to take it out again, compress the springs, loosen the top nut where it holds the springs, and rotate the top rubber hat so the bottom mounting bolt can align to the lower control arm. Basically this procedure rinse and repeat until it finally aligned and bolt was able to go in. On YouTube I’ve just seen guys just swapping out springs and mount it back on no problem.
I want to know what I did wrong or what I should have done for future reference. And one more thing. On my right strut when I loosened the nut on the top rubber mount, the square off stem/base was loosening as well when I loosened the nut ( will have a second pic showing what I’m talking about). When I was retightening with the new spring on I just tightened and held the base in place as I was tightening the nut. What does that base/stem do? Should I be worried it was loosened at first?
I know it’s a read and I appreciate you guys helping me out. Tomorrow I’ll swap out the rear springs, judging from videos it looks a lot more simple to do than the fronts, fingers crossed
