Right, I was worried it wasn't working on a brand new car. I bought mine in Dubai I'm starting to see some similarities, reverse light only one bulb works (I don't know which genius chose to do that) and we get everything from the Performance trim except the 9 inch infotainment screen, weird decisionsthat is how it works for a Canada Spec Z
I'm guessing that the ME spec is identical to the Canada spec thenRight, I was worried it wasn't working on a brand new car. I bought mine in Dubai I'm starting to see some similarities, reverse light only one bulb works (I don't know which genius chose to do that) and we get everything from the Performance trim except the 9 inch infotainment screen, weird decisions
you're right, If I twist the middle portion of the indicator there is a fog lamp icon and the fog lamp indicator stays on until I twist it again. Thanks for this tipIf this is the case, then you will have a rear fog lamp. On your signal/light stalk, there should be a button/pullout for the rear fog.
Sounds the same as the CDN spec car, maybe minus the block heater
